Re: Which is the best head set
you have not mentioned your budget but if you have a low budget then go for any of the local brands like zebronics Rs 100-250, i always buy the one with big ear muffs they have good sound and good comfort, and if you are not on a low bugget then i would suggest you a philips, you get these in any of the music world or planet M outlets, but you could get the same from any of the computer shops at cheaper prices. this should cost you say Rs 800-1000
I am Acrophobic, Entomophobic, Melissophobic. :).
