Re: What should be the real speed for 256kps connection?
Download managers show speeds in
KBps - Kilo Bytes per second.
Companies advertise speeds in
Kbps - Kilo Bits per second.
So, basically the speeds you should be getting is 256Kbps/8 = 32 Kbps.
And you're getting 30KBps, which is quite normal.
Do what you will; but not because you must. -- Zen Quote
