Old 10-03-2008, 12:52 AM   #1 (permalink)
mohanty1942's Avatar
Default Registry Backup in Spybot S&D
Q(1) When we run spybot Search & Destroy for the first time after installation, it prompts for "creating registry backup". If I skip it that time & want that option later - how to get that option anytime after first run ?
Q(2) What are the changes actually performed by Spybot S & D during the process of applying immunization ?
No Terms : Just One Condition
mohanty1942 is offline
Old 10-03-2008, 01:12 AM   #2 (permalink)
Juke Box Hero
Default Re: Registry Backup in Spybot S&D
1) Go to Mode menu and select Advanced Mode. A bunch of options will open up under Settings in the left hand side pane. It must be there.
2) I'm not exactly sure about Immunization but think that it checks for problems based on criteria as set in the programs parameters for certain files.
Someone will reply you better, just wait.
Hitboxx is offline
Old 10-03-2008, 01:22 AM   #3 (permalink)
(1) Before putting the question I had already checked the options in Advanced Mode also. I didn't find that option there. I am using Ver 1.5.
Old 10-03-2008, 09:03 AM   #4 (permalink)
motobuntu's Avatar
go to Advance Mode>Settings>Settings>Wizard
there u'll get the option to create registry backup
A computer once beat me at chess, but it was no match for me at kick boxing.
motobuntu is offline
Old 21-08-2008, 10:21 PM   #5 (permalink)
Thank you 'Motobuntu' a lot for your reply. I appreciate your answer with a big thanks since you are the only person who gave me the exact reply I i needed it after such a long break.
Please put few words so that i can know that you got my msg.
Old 22-08-2008, 12:18 AM   #6 (permalink)
Wandering In Tecno Land
Ecko's Avatar
During Immunization hosts files are updated to Exclude or include any website as trusted or not
Born in Windows Die In Linux © 2009-10 All Rights Reserved.
Learn Linux : www.linoob.com (Official WebSite)
Ecko is offline
Backup : Norton & Spybot definations ! ! ! ax3 Software Q&A 7 10-05-2007 01:11 PM
System Mechanic Pro registry backup Kiran.dks Software Q&A 1 28-09-2006 12:42 PM
Registry backup ! ! ! ax3 QnA (read only) 5 24-02-2006 05:06 PM
registry backup means hd backup????? magnet QnA (read only) 3 01-04-2005 11:00 PM
