Old 11-04-2005, 05:22 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default how to enable my TASK MANAGER ?
HELP ! my 'task manager' seems to have got disabled. how can i 'enable' it again ? pls help by giving detailed instructions.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 11-04-2005, 05:31 PM   #2 (permalink)
disabled as in ? If option is not visible to you or disabled and you cannot enable it then you probably do not have administrator rights . Login with admin credentials and you should be able to see the task Manager option.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 11-04-2005, 06:38 PM   #3 (permalink)
swatkat's Avatar
If you dont have rights (if it's disabled by Admin), then you cant use Task Manager.
But you can use alternative tools for viewing/killing Tasks, like Process Explorer or Process Viewer of HijackThis.
http://www.sysinternals.com/ntw2k/fr.../procexp.shtml
http://www.majorgeeks.com/download3155.html
http://swatrant.blogspot.com/
swatkat is offline
Old 12-04-2005, 01:39 PM   #4 (permalink)
anandk's Avatar
mine is a single user pc, with myself being the only one using it.
now when i right click on the task bar, the Task Manager option in the menu appears lighter (disabled), since the last 2 days, compared to the other entries like Toolbars, Lock the Taskbar, Properties, etc. And nothing happens when i click on Task Manager !
i logged on in the safe mode. first as an Administrator, and yes i could see
and operate the Task Manager.
then i logged on in the Safe Mode as ACK (my personal Settings), and i could NOT see the task manager. earlier on, i could see and operate the task manager in all modes.
another thing i also just noticed that, several of my applications like
AdAware, Spybot, SpySweeper, etc, NOW, just work only in the Safe Mode; but they fail to even Start-Up in the regular mode.
the problem seems to have occured at the same time.
kya gadbad hua hai, can anyone help ! ?
Microsoft® MVP
anandk is offline
Old 12-04-2005, 08:54 PM   #5 (permalink)
anandk's Avatar
found problem had used 'fix-it utilities'. created problems. restored back-ups. solved problem. thanx anyways, guys !
moral : take care b4 using utilities blindly.
Microsoft® MVP
anandk is offline
Old 12-04-2005, 11:44 PM   #6 (permalink)
swatkat's Avatar
What is that Fi-It utilities? Is it Fix-It Utilties?
swatkat is offline
Old 24-04-2005, 08:00 PM   #7 (permalink)
anandk's Avatar
yes. fix-it utilities.
Microsoft® MVP
anandk is offline
Old 24-04-2005, 08:55 PM   #8 (permalink)
ok! man try this one! too ..
if U r on a XP pro type gpedit.msc at run .. then follow the path as suggested here: User Configuration > Administrative Templates > system > Ctrl+Alt+Delete options > then in right panel look for .. remove task manager option option .. U must find it enabled . .disable it!
I hope this might just solve ur problem try it! .. & dunt forget to click on apply after disabling this option!
gud luck
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
