Old 08-03-2008, 07:47 PM   #1 (permalink)
Default pls help torrent not donload at night 2am to 8 am
dears all,
i use BSNL dataone home plan500.
i facing problem from some days that torrent download not start in night 2am to 8 am , but torrent download work fine in day, what is proper cause i dont understand.
i use utorrent with ipfilter.
pls help
thanx
dinesh1 is offline
Old 08-03-2008, 07:56 PM   #2 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
Default Re: pls help torrent not donload at night 2am to 8 am
whr r u frm ?? m frm chandigarh n BSNL is switching to underground cabling dese days hence m unable to download nd link's often down in d daytime as well..may b dats d reason
akshaykapoor_3 is offline
Old 08-03-2008, 08:01 PM   #3 (permalink)
thanx akshay
use brodband via phone line on pillers
and download of torrent file are very good before 4-6 days, but presantly download speed in 0 in night, specialy 2am to 8 am , i thik bsnl work behind this to reduce download amount. a am from bhilwara(rajasthan)
dinesh1 is offline
Old 08-03-2008, 08:19 PM   #4 (permalink)
ancientrites's Avatar
why dont u try bitcomet?
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is offline
Old 08-03-2008, 08:22 PM   #5 (permalink)
BSNL Sucks!!!
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
boosters is offline
Old 09-03-2008, 12:00 AM   #6 (permalink)
thanx ancientrites
aaj raat mein bitcomet use kar ke dekhata hu
dinesh1 is offline
Old 09-03-2008, 02:50 AM   #7 (permalink)
TooR
alok4best's Avatar
Suggestion: They might be blocking ports used by P2P systems. Go to Utorrent preferences-->Connection and enter 80 as port of Incoming connections .. . Port 80 is the default port for HTTP, i.e Browsing and BSNL wont block browsing..so why not exploit this...Also dont forgot to enable the encryption thing in Utorrent so that no one knows what is the type of Data u r actually downloading.
I wish !!
alok4best is offline
Old 09-03-2008, 09:10 PM   #8 (permalink)
thanx alok4best i will try
dinesh1 is offline
Old 09-03-2008, 11:27 PM   #9 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
If u are saying to do this way---> OPTIONS > >PREFERENCES > CONNECTION and then changing the "PORT USED FOR INCOMMING CONNECTIONS" value to 80
Then it might no help him, coz if he is using any blocking s/ware such as PEER Guardian then it will disallow the use of connections from HTTP.. coz it allows only TCP adn UDP connections) DEFAULT is "HTTP DISABLE" in PEER GUARDIAN
@ Dinesh: It might well be the case with ur ISP (coz as u said that the torrent d/loads work okay at day time) so u better check up witht eh BSNL ppl office..
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 10-03-2008, 10:46 PM   #10 (permalink)
TooR
alok4best's Avatar
Cheers n e-peace...
Dude, how many ppl in India use peerguardian..or even know abt it.
in fact in India u do not need PeerGuardian at all..hehehehe
who is there to monitor what u do with torrents. .
So my answer was based on default options.
P.S. Even I do not use peerguardian. coz never felt the need to use it.
However I do use greedytorrent sometimes.
I wish !!
Tri-Band Night UL iMav QnA (read only) 15 11-03-2008 06:55 PM
how do the torrent site know that i am dwnloding torrent?is it spyware???? tango_cash Software Q&A 1 15-02-2007 03:38 PM
Downloading at night? genxcoder Internet & WWW 14 16-04-2006 06:55 PM
