Old 11-04-2005, 12:29 PM   #1 (permalink)
Default Copying a copy protected CD
Dear Frinedz,
I have a Studio 8 CD (original) which I want to make a copy in case the CD becomes unusable. But the CD is copy protected (i.e it does not install from a copies CD). How can I make a copy of this CD for my own archival purpose.
Thanks.....
rajzoo1 is offline
Old 11-04-2005, 12:56 PM   #2 (permalink)
Install Nero and the image drive that comes with it.
Then create a cd image using the image drive ,then write the image on to a cd.
try installing from the image to see if it works (since itz copy protected )
C2D@ 2.4Ghz,Asus P5B Dlx,2X1GB Kingston@677 Mhz,Viewsonic 20",Sparkle 7200 GS ,SB Live Audigy on Creative Inspire T7900,Leadtek WinFast XP TV Tuner,Storage :Seagate 320GB + WD My Notebook 1TB
blacklight is offline
Old 11-04-2005, 01:41 PM   #3 (permalink)
use alcohol. It comes with a variety of options whiche enables you to copy a protected CD. Theres also Blindwrite which will give you exact copies of a CD.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 11-04-2005, 03:49 PM   #4 (permalink)
kl_ravi's Avatar
That's right. Alcohol 120% is the best software to backup copy protected CD's. It can copy Cd's protected by SecuRom, SafeDisc, Laserlock etc..
kl_ravi is offline
Old 11-04-2005, 04:50 PM   #5 (permalink)
Default USE THE BELOW MENTIONED PROGRAMS TO MAKE A WORKING COPY.
Arey bhaiya,first you install the program "DAEMON TOOLS" which is a freeware available on the internet.Next go to its help menu by right-clicking on its icon present near the clock.There you can get answers to all your questions in the help manual.More over also find the 'copy protection used in the cd' by using another freeware "CLONY XXL".These two tools should solve your problem 99%.Don't forget to also have ALCOHOL 120 program for the above purpose 0f remaining1% success. 8) 4:52 P.M.(Replied).
Don't forget to send an e-mail to me.
Narasimha
K.R.L.Narasimha is offline
Old 18-04-2005, 11:50 AM   #6 (permalink)
Dear Friends
Thanks a lot for your help..
rajzoo
rajzoo1 is offline
Old 26-04-2005, 10:34 PM   #7 (permalink)
Hulo's Avatar
Default Re: USE THE BELOW MENTIONED PROGRAMS TO MAKE A WORKING COPY.
Can anyone explain to me how copy protection schemes are implemented in audio CDs and Data CDs? Also, is it possible to bypass HASP hardware dongle based copy protection?
Join IGNOU MCA Students' Forum -- http://www.santanu.in
Hulo is offline
