Ask yourself where does the beeps comes from ?
I think beeps are from CD-ROM. To be precise, after switching on the Computer, the LED of CD-ROM blinks twice and then off. Thereafter, there are three short beeps. After few seconds, the process repeats and I have to switched off the Computer. During this whole process, Monitor displays nothing.
From all the replies so far can I figure out that there is some hardware problem? May be RAM or graphic card.
To recall, if it has some significant, during last three or four months, while playing Cricket 2004, I had received twice or thrice a message that my graphic card has stopped functioning properly and computer hangs with blurred wallpaper and icons on desktop. I had restarted the Computer and it started fine as such I ignored it.
I am not a Computer expert. Will I be comfortable while fitting RAM or Graphic Card properly. I mean to say that what precautions I have to take to do it myself.
Configuration - AMD Athlon XP 1600+ 1.4 GHz , 266 MHz FSB, 128 MB PC2100 DDR SDRAM, 40GB Ultra DMA HDD, 52X CD-ROM drive, Integrated S3 Pro Savage with 32 MB Shared Memory Architecture, 3.5 inch, 1.44 MB diskette drive.
http://www.arunshakya.blogspot.com
