Old 05-03-2008, 03:56 PM   #1 (permalink)
Multicore Mutant
Default RF interfernce from pc.
Few channels on cable tv gets distorted whenever the pc is on. This happened after i replaced my 845 mobo with a new 865. What to do ?
Hackattack is offline
Old 05-03-2008, 04:58 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: RF interfernce from pc.
You can't do anything Switch off the PC while watching TV.
On a serious note, you can try changing the power source of your TV.
narangz is offline
Old 05-03-2008, 05:13 PM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: RF interfernce from pc.
Check for a option named "Spread Spectrum" on advanced setup on your BIOS. Enabling this settings sometimes solved the problem. Give it a try.
debsuvra is offline
Old 05-03-2008, 06:24 PM   #4 (permalink)
Multicore Mutant
^ just now tried as u said, enabled spread spectrum but didn't help.
but i am having the same problem even with the tv tuner in my pc.
Old 05-03-2008, 10:04 PM   #5 (permalink)
Web developer
narangz's Avatar
^^ Do you have the cable connected to both TV & TV tuner card in your PC?
narangz is offline
Old 05-03-2008, 11:37 PM   #6 (permalink)
Multicore Mutant
Yes, but it happens even if i disconnect and take the wire away from the pc.
Never happened with my earlier dead gigabyte 845gv mobo.
Also i have another new 810e mobo with the same problem, both from an unbranded manufacturer, not FCC compliant. The 810e seems to affect on different channels though.
Old 05-03-2008, 11:52 PM   #7 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: RF interfernce from pc.
Then it is clear that the MoBo is the culprit here. Change and use other, simple!
debsuvra is offline
Old 06-03-2008, 12:11 PM   #8 (permalink)
Multicore Mutant
Then give me some simple cash
Old 06-03-2008, 04:36 PM   #9 (permalink)
Web developer
narangz's Avatar
Will Internet cash do? I mean images
A suggestion- Always buy FCC compliant products.
narangz is offline
