ok now what the problem is that i wanna remove Edit with MP3 Audio Editor option from context menu but i dont know how. i had this app but uninstalled it days ago but this option is still there.
^^ Open RUN and type regedit and press Enter. It'll open Registry Editor. Now goto following location:
HKEY_CLASSES_ROOT\.mp3
Under this key, check in both "Shell" and "Shellex" keys and if you find any key related to "MP3 Audio Editor", delete it and your problem will be solved.
