Old 10-04-2005, 03:23 PM   #1 (permalink)
Default Help with task manager
is it possilble to end a task without using task manager? i have a restricted account and often need to end tasks but am unable to do so?
rohit_z2k is offline
Old 10-04-2005, 05:47 PM   #2 (permalink)
swatkat's Avatar
You can use this tool called Task Killer to end tasks. It's trialware.
http://www.files32.com/info14114.htm
http://swatrant.blogspot.com/
swatkat is offline
Old 10-04-2005, 06:16 PM   #3 (permalink)
is it possible to do this via means of a batch file??
Old 10-04-2005, 06:34 PM   #4 (permalink)
swatkat's Avatar
Get it here!
http://www.jsifaq.com/subI/tip4000/rh4010.htm
swatkat is offline
Old 10-04-2005, 08:39 PM   #5 (permalink)
Thanx swatkat!!
Old 10-04-2005, 08:59 PM   #6 (permalink)
If you r using win9x os then Norton Crashgaurd can do the job.
But i think you wont be able to run these system tools under your limited account.Contact your system administrator.
amitsaudy is offline
Old 11-04-2005, 01:37 AM   #7 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. You can use Process Explorer for that .. It can run on Non Admin accounts too .. I use it as replacement to my Task Manager...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
