Old 03-03-2008, 12:44 PM   #1 (permalink)
Default Pc Is Turtoise
My PC Configuration is
Gigabyte motherboard
Intel P4 2.66 Ghz
I GB DDR ram
Window Xp Pro Sp2
But my computer is running very slow and my friend computer intel celeron is running faster than my computer.
What i have to change smps or cooling fan.
Tell me immediately.
gapchoo009 is offline
Old 03-03-2008, 12:47 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: Pc Is Turtoise
If the PC is not heating too much
than you dont need to change any Hardware Device like fan or smps
it can be a Software Problem
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 03-03-2008, 12:51 PM   #3 (permalink)
there is no software problem
Old 03-03-2008, 12:54 PM   #4 (permalink)
Tech.Masti's Avatar
Do you install lots of software? Lots of software will make your pc slow. Also clear temp directory
Tech.Masti is offline
Old 03-03-2008, 12:55 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
it can be a virus prob also
is your PC heating too much ?
satyamy is offline
Old 03-03-2008, 01:45 PM   #6 (permalink)
Fullbring
Zangetsu's Avatar
to chec whether its a soft prob or hard prob
1.format & reinstall OS
2.fully scan ur HDD with an up2date antivirus
3.use process-explorer 2 chec any anonymous background process
even after following option1 ur pc is runing like a tortoise then definitely
its a hardware problem (may be with ram,HDD or processor)
Zangetsu is offline
Old 03-03-2008, 03:49 PM   #7 (permalink)
niku_19jan's Avatar
formatting is nt the sol...many prob cause pc to slow down.
virus, unnecessary services, reg etccc.
so do all the xp tweaks thn run reg cleaner, virus scanner, n also increase ur page file. defrag ur hdd.
niku_19jan is offline
Old 03-03-2008, 03:49 PM   #8 (permalink)
dOm1naTOr's Avatar
if exploring the HDD is lagy, maybe some bad sectors has shown up
do a check disk
run>cnmd>desired partition:\chkdsk/f
this will dismount the partition and try to fix any bad sectors if any.
and also try a clean install of XP on some other partition other that the current one.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Pc Run Like Turtoise gapchoo009 Hardware Q&A 3 03-03-2008 02:04 PM
