BUG OR PROBLEM :-
media center 10 gives error message "#error 31" and sometimes "#error 33" and craches after that.
reinstalling doesn't solves the problem
computer:-
P4 1.59 GHZ
224 MB SDRAM
WIN XP PROFESSIONAL BUILD 2600 SERVICE PACK 2
MEDIA CENTER VERSION :- 10.0.1xx (I CANNOT REMEMBER IT BUT IT IS 10.0.139 OR 10.0.173,etc)
DIRECT X 9.0C REDIST
REAL PLAYER 10 ( VERSION 6.0.1408.34)
QUICK TIME 6.5 PRO (REGISTERED)
WINDOWS MEDIA PLAYER 10.00.00.3646
RIO PLAYER'S LATEST VERSION
WINAMP 5.05
i have put a signal of my radio to the line in jack.
now i want a software which can record the sound from the line in jack .
it should record direct to disk . it should also normalize the recording and also split into multiple files .
i know audacity also does it but if i record continuosly 2 hrs then it takes too much time in saving .
so i want a software which can also record direct to disk and in multiple files. but the most important thing is that it should simultaneously normalize the sound.
for example i start recording and it directly records to a mp3 file of length 10 minutes each continuosly with normalize feature.
it should be automatic
