Old 10-04-2005, 10:39 AM   #1 (permalink)
Default HP Notebook Not starting
Hello..
I got HP note book. Using Xp home edition. When I boot the pc, it shows windows Xp logo and then stops instead of asking for administarion password. I tried reset option also..
But NO use..
What may be the probel,m>?
Please answer..!!!
ranjithbajpe is offline
Old 10-04-2005, 12:06 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
well firstly try loading XP in safe mode
and remove all the entries from the startup
start>run>msconfig>Startup
so is there any other OS installed on it?
if the windows has bee messed up too much, then use their recovery cd or else do a fresh install manually, if this doesnt help
Sourabh is offline
Old 11-04-2005, 10:40 AM   #3 (permalink)
Default Xp error
I tried all the methods like, start in VGA mode, safe mode. But it stops in win XP logo.
Please help me
Old 11-04-2005, 04:26 PM   #4 (permalink)
hav u used the restore cd ? it restorz the laptop to factory settings (like when you got it)
but remember, if u do so, u will lose all ur data
if u got sum really important stuf, u can use a boot disk 2 start ur pc in dos and use FLOPPY drives to back it up
if theres too much data and its really very important and u can go any lengths to keep it, do this:
1.start it using a bootdisk in DOS
2.install sum old version of windows like 98 or ME
3.then using a network or cd writer, backup your data
4.use the RESTORE cd
ishaan is offline
