Old 10-04-2005, 01:25 AM   #1 (permalink)
Default LOCKING CD FROM COPYING
I hava program that can lock exe files on a cd which will noe work on the hdd. Also u cannot copy the cd.
Is there ne way by which i can lock other files too. Other type of files i mean.
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
Old 10-04-2005, 02:18 AM   #2 (permalink)
sms_solver's Avatar
what exe file do u have? can where can we get it
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 10-04-2005, 12:39 PM   #3 (permalink)
Technoholik !!
Tech&ME's Avatar
Default Re: LOCKING CD FROM COPYING
Can you provide me / us with a weblink to this program you are referring to ? Would like to try it myself.
[Desktop]
[Laptop]
Tech&ME is offline
Old 10-04-2005, 12:54 PM   #4 (permalink)
do u mean it locks all .exe files from copying? where can i get it? did u know the way for blocking the whole cd from being copyied?
chanduthebest is offline
Old 10-04-2005, 03:19 PM   #5 (permalink)
what about audio and video CDs?
valtea is offline
Old 10-04-2005, 03:46 PM   #6 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Hey guys i wanna join his discussion related to lockin of .exe files from being copied from Cds as this will prevent any illegal copying of my game Cds,documents and also songs.
do post the link/url from where we can get such type of software..
thanx,
cheers n peace
ashu888ashu888 is offline
Old 10-04-2005, 03:50 PM   #7 (permalink)
vysakh's Avatar
gimme
Incompatible message format
vysakh is offline
Old 10-04-2005, 10:45 PM   #8 (permalink)
Default same here
can i have the link or name of programe to study it further....
__...:::---*Keyboard Cowboy*---:::...__
whistler is offline
Old 13-04-2005, 08:13 AM   #9 (permalink)
Yeah guys! I will put up the link. Right now I cannot. I am in a cyber cafe.
Well the software locks exe files. So if u need to make ur own stuff...just make a exe file and lock it up on the cd.
U cannot create an image file of the exe file as all image recorders give errors.
Also if ou simple copy the protected exe file on to your hard-disk it gives an error of hard-disk copy not allowed. And continues to give the same error even if you write that file again on another cd. But the software has 20 usages trial limit.
Old 13-04-2005, 06:48 PM   #10 (permalink)
ramprasad's Avatar
Hi guyz
Gimme the link....as I am ready for the weekend...
Regards,
Ramprasad
ramprasad is offline
Old 13-04-2005, 07:58 PM   #11 (permalink)
Šupər♂ - 超人
koolbluez's Avatar
I've heard of TZ Copy Protection, never tried it though.
Maybe this should clear up few doubts.
koolbluez is offline
Old 13-04-2005, 10:44 PM   #12 (permalink)
Rebooting
Choto Cheeta's Avatar
if u have it then gr8 job... but u know we had this kind of bluuuuufffffsss a lot.... like take a example of the software that can make CDRW drives to read DVD disks...... well mate dont mind ok.... i just posted a coment on this topic.... so again DONT MIND....
Choto Cheeta is offline
Old 13-04-2005, 11:02 PM   #13 (permalink)
Ready to storm in this part of DIGIT.......................
The link..... [Pls keep posting in this topic abt the software]:
http://mindestworx.free.fr/
Keep Rocking, Keep Locking guys!!!
Old 14-04-2005, 11:54 AM   #14 (permalink)
nice search. Thanks for the link
valtea is offline
Old 14-04-2005, 04:20 PM   #15 (permalink)
Default one more here
Copy Killer
CopyKiller is a program to protect your own cds.The program makes damaged sectors on cd and disables so 1:1 (Raw) copies. It checks if it really is the original cd at every start up of the cd. CopyKiller protects Data and Audio CDs. But CopyKiller does not work with every writer, because it uses a firmware error to make the cd copy protected.
Discription Here
whistler is offline
Old 14-04-2005, 04:29 PM   #16 (permalink)
Default Also check thease
Also check these:-
1) SerialShield Protection SDK
2) ShareGuard_Copy_Protection_v1.5
3) SoftwareKey_Trial_Creator_1.10
4) SoftwareShield_System
5) CDSHIELD 1.05 Cd protector software
6) Crypt CD
Do a GOOGLE as i cant provide link for each of them....
ne how i havnt tried any of those, so cant comment....anyone else care to comment on any of them?
whistler is offline
Old 14-04-2005, 04:31 PM   #17 (permalink)
Did every one forget abt the softwares like Bad copy pro ? does it work recover the files to the hard disk ?
vijaythefool is offline
Old 14-04-2005, 04:55 PM   #18 (permalink)
Default ne 1 care to post view?
i havnt d/led any of those so cant comment about the algorithm it uses to protect those cd's...but if any of those works, IS BILL GATES LISTENING..
in any case iam wathing this constantly if anyone cares to download any of those and post his comments and results...
whistler is offline
Old 16-04-2005, 11:34 PM   #19 (permalink)
I tried using bad copy pro and isobuster over the cd protection of cd shield. Wat it does is it just copies the program which gives an error of hard disk copy not allowed.
The only we it cud work is get a disc image of the cd. But i tried 5-6 image recorders, all failed to make an image!
Old 17-04-2005, 11:08 AM   #20 (permalink)
theni got to try out that
Old 19-04-2005, 01:25 AM   #21 (permalink)
Hey people i'am still to try one of those softwares ..but can any software protection escape the dd command of unix/linux ...to make an iso image of the cd??
surdy is offline
Old 21-04-2005, 03:57 PM   #22 (permalink)
Dont know abt linux. But @least windows cannot beat it. Will try on linux. May b ij just fails tooo!!!
Old 23-09-2005, 03:41 PM   #23 (permalink)
9437077259
go4saket's Avatar
Hey Aseem, the link provied by u leads us to a web site with no matter. Can you please ckeck the link again...
go4saket is offline
Old 23-09-2005, 09:34 PM   #24 (permalink)
Ishan's Avatar
Default hEY i HAVE ONE
I have the software CD Lock but don't know how to use it? I f any one then plz inform.
Ishan is offline
Old 24-09-2005, 08:05 AM   #25 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
will alchohol 120% not be able to copy are u sure?
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 25-09-2005, 09:32 AM   #26 (permalink)
champ_rock
champ_rock's Avatar
that cd shield 20 times usage limit can easily be bypassed by editing the registry
HKEY_CURRENT_USER\Software\CDSH\home
then the key trl denotes the no. of times u have used the software.
make it 0
trl =0
Registered Linux user number 400618
champ_rock is offline
Old 25-09-2005, 03:39 PM   #27 (permalink)
champ_rock
champ_rock's Avatar
i have made a bincue file from cdrwin... i have locked it using cdshield but when i try to write it on a cd using cdrwin it shows that no supported cdrom was found??????????????
what the hell is the prob... and also when i try nero it says error in *.cue file (line1)
Old 25-09-2005, 04:05 PM   #28 (permalink)
vignesh's Avatar
Is locking really possible.
vignesh is offline
Old 25-09-2005, 08:40 PM   #29 (permalink)
champ_rock
champ_rock's Avatar
i would say definately yes.......... i mean we cant buy large cd writing machines but some amount of some sort of smart coding makes a smart program.. which makes it possible
Old 26-09-2005, 04:55 AM   #30 (permalink)
Fresh Stock Since 2005
Did you try Alcohol 120%??
http://www.khattam.info
khattam_ is offline
