Old 29-02-2008, 02:49 PM   #1 (permalink)
ramprasad's Avatar
Default DVD Not readable
Hi,
I wrote few GBs of pics from my friend's laptop (HP-I dont know the model) to a Verbatim DVD+R using Nero as a data disc.
It completed the burning without any problems.
When I re-inserted the DVD back in the same system, Windows XP said that the format is not supported and cannot read the disc.
Same error popped up when I tried to read the DVD in a PC too...
Can anyone throw some ideas as how to get around the problem and try to read the data from those DVDs...?
Could it be brand compatibility...?
If that is the answer, I also tried burning Verbatim CDRs and it works perfectly fine.
Thanks in advance
ramprasad is offline
Old 29-02-2008, 03:05 PM   #2 (permalink)
pushkaraj's Avatar
Default Re: DVD Not readable
did u try using the dvd in some other pc? i think the problem is coz the dvd was a dvd+r.
The statistics on sanity are that 1 out of every 4 humans is suffering from some form of mental illness:shock:
Think of your 3 best friends. If they are OK, then it's YOU:grin::grin::grin:
pushkaraj is offline
Old 01-03-2008, 01:37 PM   #3 (permalink)
Elevating Humanity
The Conqueror's Avatar
make sure u do lead out else it wont be readable in other systems
Regards,
The Conqueror
The Conqueror is offline
Old 02-03-2008, 11:59 AM   #4 (permalink)
pushkaraj's Avatar
^^ But Nero does lead-out on its own.
.avc and .lst extension readable software thecreativeboy Software Q&A 5 31-10-2007 03:13 PM
Unix text to notepad readable text? How? adithyagenius QnA (read only) 4 09-06-2007 07:27 PM
