You can leave those entries as it is, they are related to somw Windows components. If you have already removed, there will be backup files in the folder where ToolBarCop is present, these will be .REG files. Open those files in NotePad and then look for the entry you removed, when you find the correct file, close NotePad, and simply double-click on the .REG file that is to be restored.
http://swatrant.blogspot.com/
