Old 28-02-2008, 08:37 PM   #1 (permalink)
harryneopotter's Avatar
Default Upgrading RAM ...Plz Help....
Hi Guys .... I have the following Config....
AMD 3600+
M2NPVVM
512 x 2 667 kingston
Now i want to upgrade my ram .... so i am thinking to go for 2 gb more .... now i have a few doubts ...
Whether i should go for 2 x 1 GB 667 or 800 mhz ......
i knw with my present set of RAM ... 800 mhz kit will also run at 667 .... but in future i can dump my 512 set .. and buy another 2 gb set (800MHZ) thn it will be fine ..... but will it be a significant performance boost as i have heard that RAM frequency dsnt matter in AMD system (but the latency timings does matter) ... so is it wise to pay a few hundred bucks xtra for 800 mhz RAM for the performance ?
Also only Trancsend 800 Mhz RAM is available here ....
So shld i go for 2 x 1 GB 667 Kingston or 2 x 1 800 Mhz Transcend in combination with my present set of 512 x 2 667 Kingston ?
Price of 667 Kingston here - 900 /-
price of 800 Transcend here - 1050 /-
Plz help .....Thnx
harryneopotter is offline
Old 28-02-2008, 08:49 PM   #2 (permalink)
Intel OCer
amitash's Avatar
Default Re: Upgrading RAM ...Plz Help....
800Mhz RAM will give u a very good performance boost if u are into heavy stressing,overclocking,or even hi-performance gaming...if u are just a casual user with no use for any of the above go for the kingston...although if i were u i wud get the 800Mhz RAM...more is always better and its only 150 bucks extra so i wud go for the 800mhz RAM...
amitash is offline
Old 29-02-2008, 08:44 AM   #3 (permalink)
NBC(Next Bill Candinate)
100.dx's Avatar
go for transcend
100.dx is offline
Old 29-02-2008, 12:23 PM   #4 (permalink)
thnx guys ...but i expected more detailed explainations to convince myself to go for transcend ... actually i am a bit short of funds right nw .... so is it wise to go for 800 Mhz instead of 667 (the price diff of Rs 300 may be nuthing 2 u ..but its steep for me ...) keeping it in mind that i will be using the new RAM with my current 667 mhz modules ....
And about my usage pattern .. i do rip some movies now and then, sumtimes i play crysis, i am planning to learn MAYA or 3d MAX or Flash in near future ..... other times its just DVDRIP movies, surfing, and other games etc ...
SO plz suggest .....is the 800 MHZ will give a significant boost for me to justify the price diff on my AMD SYSTEM.......(if i use it with my current 667 mhz set) ???
Old 01-03-2008, 12:27 AM   #5 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Well even if u buy the 800Mhz RAm, it will still work at 667 Mhz (to compensate for the remaining modules),
But, if ur mobo supports 800 Mhz RAM and as u said abt future (tat u will add extra RAMs of 800 Mhz), its better to go for 800 Mhz as of now (coz as of now it will work on a lower speed of 667 Mhz (to compensate for the remaining modules wich are 2x512 MB (667))
but, later wen u upgrade it to all 800 Mhz Modules (by removing the 667 Mhz modules), then u will hv a boost in performance.
Provided, they are in DUAL CHANNEL and ur mob supports 800 Mhz RAM Modules.
:Off topic: I hv 4x512 MB DDR(400) Transcend RAM for my P-IV, 2Ghz system.
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 01-03-2008, 10:26 AM   #6 (permalink)
So its 800 Mhz RAM now ... as my mobo do support 800 Mhz Memory with dual channel...... thnx guys .........
Old 01-03-2008, 11:13 AM   #7 (permalink)
Yup, then thats ur best bet.
But be sure to buy RAMs in pairs order so that U can have them connected in DUAL CHANNEL mode (as that will definately hv an added advantage than a single module)
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
upgrading old p3 help please tamalsen Hardware Q&A 6 04-10-2007 09:52 PM
upgrading .......... salilrane Hardware Q&A 7 17-12-2006 08:25 PM
upgrading rd ram help thadhanihemant QnA (read only) 3 16-07-2006 05:05 PM
upgrading ram - help dotcommakers QnA (read only) 10 13-12-2005 12:37 AM
Upgrading Sarwesh QnA (read only) 3 14-09-2005 01:58 PM
