I use Free Downlod Manager.when i reinstall windows.i have to start a download from beginning.is there any method may enable to resume that download.can i insatall it in differnt drive for that purpose? Any suggestion.
Why do you reinstall windows that much frequently. To do this, you will have to move a lot of files to other drives and some registry editing as well which you may not like
You should have exported the list and settings before reinstalling XP. That way you could have imported the same and resumed your downloads. Make a backup of your incomplete download and try redownloading to the same location. If it resumes, ok, else you have to restart from the beginning !
