Old 27-02-2008, 07:46 AM   #1 (permalink)
avtarkaint's Avatar
Exclamation icon problem
frnds from few days i m not getting volume & safely remove hardware icon from my task bar, some time it show but mamimum time it doesnot visible at all. i had done this process control panel>sound & devices>volume in that place volume icon in task bar is enabled but it doesnot work at all. & most important all my usb ports doesnot work at all, i had formatted my pc twice but the problem is the same at last i use expandable usb port & its work good .plz resolve my problem i have scaned my pc with avast antivirus updated one..
system:
microsoft windows XP proffesional version 2002
service pack 2, intel(r) pentium(r) 4 cpu 2.66GHz
248 MB of RAM
using- AVAST antivirus professional updated regurarly
avtarkaint is offline
Old 27-02-2008, 10:34 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: icon problem
Did u checked if the icons in the task bar are hidden ? I mean there are a small arrow towards left side that minimizes the task bar items, click on it to reveal the other hidden items.
debsuvra is offline
Old 28-02-2008, 04:28 PM   #3 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Re: icon problem
r-clickon taskbar > properties > UNCHECK hide inactive icons ....
... W H O T ...
ax3 is offline
Tray Icon Problem:: cooldip10 Software Q&A 3 01-01-2008 05:00 PM
Desktop icon problem... Lucky_star Software Q&A 5 25-11-2007 08:14 PM
Problem in displaying LAN icon in taskbar Hari_04415 Software Q&A 3 18-08-2007 05:57 PM
hi i had problem again my cd/dvd icon is missing gvrappu Software Q&A 1 06-06-2006 04:05 PM
desktop icon problem goobimama QnA (read only) 16 05-03-2005 01:14 AM
- by Piyush
