DDR stands for Double Data Rate RAM. Basically DDR RAM allows you to perform 2 memory accesses per memory bus clock. Hence you can get much higher performance than SDRAM. You need to have a motherboard wich supports DDR, though most newer ones do. DDR RAM comes in FSB variants like 266, 333, 400 etc. This is the speed at which the memory is clocked at, basically the speed at which memory can be accesssed. You will get a fair performance gain with higher speeds, especially if your proccessor has a large FSB. The p4 2.6 comes with an 800 MHz FSB, so get atleast DDR 400 RAM. 512 MB is ideal for now. As for the graphics card, it will make a tremondous impact on games, but other applictaions you have mentioned may not be affected so much. If you are a casual gamer, a geforce4 MX would do, costing 2k - 3k. If you can pay a little more, go for a radeon 9600, it is DirectX9 compliant, and much more future proof than the MX.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
