try checking the manual or intels website . I think ur board works with multiple speaker output , while ur cabinet works only for 2 speakers , ie two channel output . under normal situations , front panel audio is mainly used only for head phones , so that u dont have to go back all they way to fix a headphone , that to with a short wire . the three wires must be for Left , Right and Ground . Just try fixing ,
pin 6 AUD SPK R
pin 10 AUD SPK L
alone and check if u get sound . check if u have similar markings on the cabinet wires too .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
