Old 24-08-2004, 11:21 AM   #1 (permalink)
Default PC hangs while checking RAM & Gives Beep...... BeepBeepBeep!
Hi all,
I have Desktop PC of following configuration
266Mhz Celeron, RAM 128MB(133Mhz) + 32MB(66Mhz)
Intel Chipset i440LX Motherboard, Intel i740 AGP Card With 8MB Video Ram, I am using this configuration for more than 2 years with out any problem.
Some days back my PC hangs while checking RAM (power on self Test), I have tried restarting PC but dosent work. I have also noticed that my PC hangs at different points while power on self test (it dosent stuck at same location).
I have tried changing banks of RAM, Pressed (to check for any loose contact).. After that there was No display !! I pressed AGP card..now there was a display but PC is not able to do complete Power on Self Test.
Does Beep(followed by some delay).........BeepBeepBeep(no delay) mean there is no/loose diaplay/AGP card. ??
I have tried almost one day!! working on my PC...
I was not able to find any solution to above problem.. Pls help me to boot my PC...
Thanks for any replies in advance
Shailendra.
Shailendra is offline
Old 24-08-2004, 11:31 AM   #2 (permalink)
first check ur RAM
think ur RAM is dead
long contineous beeps denots RAM error
Music is like Sex, The more you get, the more you want.
demoninside is offline
Old 24-08-2004, 02:41 PM   #3 (permalink)
Ninja Jedi
Sounds like dead RAM. Apart from changing the banks did you try removing each module at a time? Also, mixing a 133 MHz module with a 66 MHz module is not a good idea at all.
Careful, I Byte!
Byte is offline
Old 24-08-2004, 05:55 PM   #4 (permalink)
alib_i's Avatar
hapenned with me when my ram was loose ....
so it seems urs is dead , if not loose !!
-Metallica
alib_i is offline
Old 28-08-2004, 12:39 AM   #5 (permalink)
da' Ťurntable ruleth
techno_funky's Avatar
happened with me just a week ago
and i lost him omy i lost it
MY RAM IS DEAD
bohooooo
ahem....
ok
yaa my ram gave up
having a DINSOUR MOBO
so had to blow a BIG hole in my wallet
3200Rs for a 256mb SD RAM
| Dell Studio 15 | iPod Touch 16GB (Stolen) | iPod Video 5.5G 30GB | Sony Ericsson W910i |
| Sennheiser PX 100 | Sennheiser HD 202 |Creative EP630 | Altec Lansing ATP 3 |
techno_funky is offline
Old 30-08-2004, 11:28 PM   #6 (permalink)
hey try removing the ram and put in another slot.. if still this problem then try getting a ram from ur friend and put it there.. if it works then problem with ur ram.. if it doesn't work then try putting ur ram in ur friends comp.. if it works there then problem with ur m/b..
Amit Prabhu is offline
Old 02-09-2004, 03:32 PM   #7 (permalink)
spykids_666
Posts: n/a
UR RAMS DEAD!!!!!
UR RAMS DEAD!!!!!
UR RAMS DEAD!!!!!
THAT THE MEANING OF BEEP, BEEP, BEEP, BEEP IN THE COMPUTER LANGUAGE.
R.I.P.
Old 02-09-2004, 08:13 PM   #8 (permalink)
Let the music play.....
djmykey's Avatar
Ur rams dead. Try it on a frens machine which takes the same freq ram. if it works then either the mobo is gone or cmos battery is gone or the cmos is. Dont go to the cmos try the ram first but take care that the machine accepts 133MHz ram otherwise itll not detect the ram. Prayin that ur ram shud be alive.
djmykey is offline
- by Piyush
