Old 24-02-2008, 09:12 PM   #1 (permalink)
harryneopotter's Avatar
Default getting low speeds ...help plz ..
Hi guys ... i am using 2 mbps NU plan from VSNL .... but the speed i got from www.speedtest.net is 54kbps ........... so is it a ISP side prob ... or sumthing wrong in my windows setting ? .... Plz help ...
harryneopotter is offline
Old 24-02-2008, 09:49 PM   #2 (permalink)
dare_devil's Avatar
Default Re: getting low speeds ...help plz ..
it may be isp problem but you can little bit increase speed by disabling 20% use of bandwidth which is by deafoult reserves for windows, i did it by using ashmpoo power up from digit dvd
dare_devil is offline
Old 24-02-2008, 10:29 PM   #3 (permalink)
Check with BSNL Braodband Customer care and IF there is a heavy rain or water logging in your area then its not a big deal, you will have to go with that only.(Generally BSNL guys will change your wires and the problem will be solve as old cable slow down speed because of various reasons).
If this is the problem and you are not getting solution , Switch too Airtel.. it is sometimes better then BSNL and very good customer service. By the way i use BSNL Braodband 256 kb (unlimited) and i m more happy then who are having 2 mbps speed broadband.....
Rahuldhanpat is offline
AMD speeds morpheusv6 Hardware Q&A 12 12-01-2007 02:11 PM
My internet speeds :-o !!! MysticHalo Internet & WWW 8 13-03-2006 11:48 AM
RAM Speeds IG QnA (read only) 5 06-11-2005 01:01 PM
Low speeds, very yrana2002 QnA (read only) 2 03-11-2005 10:23 AM
airtel, slow download speeds and gr8 ul speeds. legolas Broadband and DTH 6 26-08-2005 07:47 PM
- by Piyush
