Old 08-04-2005, 11:13 PM   #1 (permalink)
Fresh Stock Since 2005
Default Problem with NAV 2005 Updating
I have a problem with NAV 2005. I have downloaded the latest Virus definition packages of NAV and installed using SmartUpdate. I also installed the latest version of LiveUpdate pogram by downloading it from Symantec website. Now, the other updates (including WMI update) do not install with the help of LiveUpdate. They are downloaded but during installtion, it says the updating failed. It also gives me a support link which is of no use.
khattam_ is offline
Old 08-04-2005, 11:51 PM   #2 (permalink)
mario_pant's Avatar
hey... norton has an inbuilt... live update feature... doesn't it??..... and it failed me a lot of times today...
The name is Mario, "Mario Pant"!
mario = avatar; pant = पतलून
and i'm NOT some mountain KiD!
mario_pant is offline
Old 09-04-2005, 12:05 AM   #3 (permalink)
I didn't quite get u...............
Do you mean that you are also having a similar problem..............
khattam_ is offline
Old 09-04-2005, 01:14 AM   #4 (permalink)
mario_pant's Avatar
um..... when i run live update... the component and virus def updates are downloaded but are not installed.... it says that virus defs are in use.... worm protection files are screwed up or something........soo....
Old 10-04-2005, 10:27 PM   #5 (permalink)
@mario
So, what are you gonna do bout it??
khattam_ is offline
- by Piyush
