Old 23-08-2004, 10:57 PM   #1 (permalink)
Default REGISTRY EDITS - PRANKS
Could u people send me some innovative pranks using the Registry?? Not ones like changing the START button or flashing a message each time windoze boots...
~YOU LEARN FROM UR FAILURES , OTHERS LEARN FROM YOUR SUCCESS...
BLITZ~KRIEG! is offline
Old 23-08-2004, 11:04 PM   #2 (permalink)
busyanuj's Avatar
well, Windows Registry isn't exactly the best place to play pranks, but surely you can get some help about specific problem.
busyanuj is offline
Old 24-08-2004, 12:52 PM   #3 (permalink)
get windows registry guides from winguides.com...has a few 100 reg tweaks that u can do it urself! a must try.
prankzter is offline
Old 25-08-2004, 02:25 PM   #4 (permalink)
http://www.onecomputerguy.com/registry_tips.htm
http://windows.about.com/cs/registrytips/
u can also change the expiration period of trial version softwares
any way ...when pranking(!!!) in registry. it'll be always good to take a back up
girish_b is offline
- by Piyush
