Old 20-02-2008, 01:16 AM   #1 (permalink)
Default i want hard disk (external)
i want hard disk IDE, that i can use externally
can anyone tell me IDE hard disk more than 320 are available or not.
i want capacity 320 Gb or more.
what are the prices .
and how much more needed to convert to external.
AMIT AGARWAL
AMITAGARWAL02 is offline
Old 20-02-2008, 01:19 AM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: i want hard disk (external)
if u need to use externally then why need IDE ?? SATA-2 (with USB casing) or eSATA (branded portable) is there
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 20-02-2008, 01:28 AM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
I think eSATA case is also there in market
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 20-02-2008, 01:29 AM   #4 (permalink)
Rebooting
yeah true
rebooting
ChotoCheeta.com
Old 20-02-2008, 01:30 AM   #5 (permalink)
The Smaller Bang
yeah true
so sataII HDD + eSATA case = INSANELY FAST EXTERNAL HDD AT DIRT CHEAP PRICE
Old 20-02-2008, 03:15 AM   #6 (permalink)
sata will do , but due to sata hard disk some months ago , mine computer got burnt. so i dont want to take risk this time. may be that time hard disk was faulty.
and what is esata.
any idea about price for 320 gb and above. and for casing.
AMIT AGARWAL
Old 20-02-2008, 03:27 AM   #7 (permalink)
The Smaller Bang
and what is esata.
hard disc type won't result in comps getting burned. It must be problem with the HDD.(not its type)
eSATA is short for External SATA. Some computers have an eSATA port, and connecting from here gives you the full speed of SATA (3.0 GBPS in case of SATA II)
case costs anywere between Rs. 600(basic) to Rs. 2000(high end esata raid, etc)
HDD of 320 GB costs Rs. 2800/-(ultra low must buy) to Rs. 4500/-(big time robing of cash)
Old 20-02-2008, 03:49 AM   #8 (permalink)
yes the hard disk was having problems.
few people also got their motherboard burnt due to this.
i dont have eSATA port so how to use sata hard disk externally.
i have 4 sata ports on motherboard but inside the cabinet.
are there hard disk with more than 320 gb also
AMIT AGARWAL
Old 20-02-2008, 07:41 AM   #9 (permalink)
TheSaint
NucleusKore's Avatar
Buy WD Passport, its good. It takes its power from the USB port. No power adapter required. Five year warranty.
See here
http://www.techgadgets.in/storage/20...es-introduced/
http://www.tech2.com/india/news/hard...-drive/27701/0
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 20-02-2008, 12:03 PM   #10 (permalink)
You can get a e-SATA bracket (i.e. internal SATA to e-SATA) & an e-SATA cable for approx 500 bucks I suppose (dunno the exact price though).
Or if available in the Market, you can go for a direct SATA to e-SATA Converter Cable.
You can have a look at this Page for a clear understanding & visual look of SATA & e-SATA conversion & cables associated with it :
http://www.addonics.com/support/faqs...ta_connect.asp
BTW, There are HDD with over 320GB - 400GB, 500GB, 750GB, 1TB.
shadow2get is offline
Old 20-02-2008, 01:30 PM   #11 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
whots diff between basic & high end esata raid casing ?
... W H O T ...
ax3 is offline
Old 21-02-2008, 06:10 AM   #12 (permalink)
thanks for all the help
but that cost 3 times more
The 320 GB capacity WD Passport Portable Drives are now available for purchase at Western Digital’s online store for a price of $229.99(approx Rs. 9,069).
we can get 320 gb hard disk for approx 3500 Rs then why spend 9000 or 8000Rs
AMIT AGARWAL
Old 29-02-2008, 05:34 AM   #13 (permalink)
Any idea what is cost of external hard disk 500 GB
and internal harddisk 500 GB please tell me price for both
AMIT AGARWAL
Old 30-03-2008, 08:23 PM   #14 (permalink)
how to protect hardisk as the hard disk is connected with power supply directly
all knows how power supply in india is . will connecting harddisk to power supply will cause any effect on hard disk if there is a problem in power supply
AMIT AGARWAL
External Hard Disk.... hell_storm2004 QnA (read only) 4 02-11-2007 06:23 PM
External hard disk blueshift QnA (read only) 17 06-09-2007 07:07 PM
Which external USB Hard Disk to buy ? esumitkumar Peripherals 12 09-01-2007 06:09 PM
External Hard Disk varun_ag QnA (read only) 12 28-04-2005 10:56 PM
- by Piyush
