Old 08-04-2005, 01:14 PM   #1 (permalink)
Default Help regarding sound
Comp configuration:
P4 1.7Ghz
Jetway 845 Chipset Mobo
256Mb DDR
40GB
Nvidia Fx 5200
AC97 Onboard Sound
Win XP
Problem:
I want to play a very old game called Fragile Allegiance(Hey, dont worry I dont play old-fashioned games, I also Play DOOM3). I installed it.
Everyting was fine. When I opened the Prog for sound setup. It told I didn't have any soundcard. And When I try to setup manually It doesn't list AC97. What do i do?I dont want to play it without sound.
Help
undertakerthedead is offline
Old 08-04-2005, 06:21 PM   #2 (permalink)
dere mite b an option for using the pc speakers....in old pcs they had dose speakers in d cabinet n many gamz used dat
ishaan is offline
Old 10-04-2005, 12:23 PM   #3 (permalink)
Gracias Senor
dreams's Avatar
ya as per ishaan the old games uses the PC speakers tht r inside the cabinet.. open sound properties and adjust the PC Speaker volume.. if it not found then go to prop and do..
..nJoy..
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 10-04-2005, 02:57 PM   #4 (permalink)
as far as i know old games work with the system speaker,and not the sound card ,check ur system speaker
NOBODY
is perfect,,, I am NOBODY
chanduthebest is offline
Old 10-04-2005, 04:19 PM   #5 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Does ur sound problem happen only for that particular game or for every game u play??
U can reinstall the sound drivers from ur Motherboard Cd and do check for lose cables and/or dust accumulation in ur speakers.
also check the sound options in ur game menu too.
ashu888ashu888 is offline
Old 11-04-2005, 10:34 AM   #6 (permalink)
ferrarif50's Avatar
Hi,
check your PC speaker volume, and keep it high
Other thing you can do is run this game in the compatibility mode.
Right click on the main executable of the game ( or the shortcut will also do ), and go to the compatibility mode.
and check the box 'Run this program in compatibility mode for' and select Windows 95 or 98.
Click and apply and now try running the game!
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
- by Piyush
