Old 08-04-2005, 10:22 AM   #1 (permalink)
Default delete partition without formatting hd /reinstall xp
i delete partition without formatting hd partition. when i boot win 98 cd
some process occur after give message fixed disk on choice format hd option or other option and stop the process?
thanks for suggation......
Rashid Ansari is offline
Old 08-04-2005, 12:35 PM   #2 (permalink)
please be more clear in your question
i am not able to get your question?
let me just guess your case
you had xp installed on your sys, you have deleted the partiton(which means removed its reference from allocation table) without formating and you are trying to install 98 and it is not installing and please mention the error it gives
might be your drive was in NTFS file system
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 08-04-2005, 05:24 PM   #3 (permalink)
since this thread is already begun
can anyone tell me how to use fdisk, its capabilities etc..
A flea and a fly in a flue, were caught, so what could they do? Said the fly, \"let us flee!\" \"Let us fly!\" said the flea. So they flew through a flaw in the flue.
technovice is offline
Old 08-04-2005, 05:55 PM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
A very nice guide I found is here and here .. ..
@ Rashid Ansari, Please be more specific in your query .. As working with partitions may cause loss of data, so we need to be sure of what you are asking ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
- by Piyush
