Old 08-04-2005, 02:13 AM   #1 (permalink)
Default IE6 installer
Hi
i wanna know from where can i download IE 6 installer for Win 98.
i am using firefox right now but it doesnt support some sites and IE supports them
Is it possible to download the plugins so that these sites can be surfed through firefox
Also there is one site where the site owner says that the site can be viewed only in IE6 or Opera-How is it possible,why cant firefox be used?
In that case are there any plugins to view the above site.
Thnx
rachitar is offline
Old 08-04-2005, 09:54 AM   #2 (permalink)
enoonmai's Avatar
Some sites exclusively check for Internet Explorer and with such sites, such as Windows Update, you're out of luck. You HAVE to use IE. This cannot be bypassed by plugins. You can download IE6SP1 for Windows 98 from here.
Playing FEAR XP/LSW2
enoonmai is offline
- by Piyush
