Old 08-04-2005, 12:17 AM   #1 (permalink)
The Hardware Labs
mohit's Avatar
Default How to damage a RAM module ?
hey guyz , i want to know if there is any possibility that I can damage my RAM modules without inducing physical damage to them and also without damaging any other part of my machine. My dealer has taken me for a ride and has given me some cheap RAM and he will replace it only if there is some problem with it and no physical damage. Need to teach this chap a lesson guyz with your help ofcourse. For my config please see my signature and advise.
mohit is offline
Old 08-04-2005, 01:02 AM   #2 (permalink)
sms_solver's Avatar
drop your ram into water for about 1 hour. take it out and the chances are your ram could be damaged. (physical damage) can not be seen.
I have not tried this method. Try at your own risk
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 08-04-2005, 09:36 AM   #3 (permalink)
Firstly i would not recommend you going in for this prank, but if you still insist here goes. Dropping RAM in water will not harm it. The best and the cleanest silent killer is STATIC so charge up a plastic device or youself by walking on a carpet whearing slippers / synthetic stuff rubbing etc and touch the gold plated pins of the modules Thats it clean swift and no traces.
**** happens
pradeep_chauhan is offline
Old 08-04-2005, 10:04 AM   #4 (permalink)
Just make sure you don't touch any other component. You don't want any fried transistors on your motherboard, do you? Detach the RAM modules and then touch it
chaos is offline
Old 08-04-2005, 01:08 PM   #5 (permalink)
ya first remove your ram from your motherboard and take as much away from your comp as you can and not taker a sweater(winter pullover) and rub it over your hair (it induces a great static charge in by body, so much that even touching the complete palm to wall genrates spark in the palm) and now just ouch the golden connectors of the ram. now just amke sure that you dont have static charge on you or on the ram and then reinstall the ram
\"I was born INTELLIGENT
But EDUCATION ruined me!!!!\"
AMD 64 3200+(Winchester), MSI RS480M2-IL, 512*2 DDR400 Hynix, Segate 80 GB SATA, LG E700SH, i-benz with Intex PS (400 W)
technoteen is offline
Old 08-04-2005, 02:19 PM   #6 (permalink)
club_pranay's Avatar
just put the connectors in series circuit with a 12 volt bulb (use AC to DC voltage adaptors as storage battries will blow the chip to bits). i like this topic
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 08-04-2005, 02:21 PM   #7 (permalink)
gxsaurav
Posts: n/a
Take it out of your Cabinet
Take a hammer & Start bam bam bam bam bam bam,
Mission compleated, RAM Distroyed
Old 08-04-2005, 02:29 PM   #8 (permalink)
thats the best way but he clearly mentioned that no physical damge
Old 08-04-2005, 03:04 PM   #9 (permalink)
The Hardware Labs
mohit's Avatar
how can i discharge myself completely from any static charge present on my body ??
mohit is offline
Old 08-04-2005, 03:21 PM   #10 (permalink)
Take a shower
and dont dry yourself
**** happens
Old 08-04-2005, 04:05 PM   #11 (permalink)
enoonmai's Avatar
Another good way and one that's preferred is to either get yourself a ESD-safe wrist strap and plug/attach it into a metal (non powder-coated) surface while you are working. You can also keep the case cover on the floor and touch the non powder coated part of the case to ground yourself.
Playing FEAR XP/LSW2
enoonmai is offline
Old 08-04-2005, 06:16 PM   #12 (permalink)
will rubbing da ram wid a magnet spoil it ?
ishaan is offline
Old 08-04-2005, 06:24 PM   #13 (permalink)
The rubbing qmight physically scar the IC or dammage the PCB apart from this : No Dammage.
**** happens
Old 09-04-2005, 09:33 AM   #14 (permalink)
Guys Have u noticed that when u switch on a monitor the screen collects a lot of static electricity
Same is the case with tv.
Well he can use that to damage the ram
Sankalp is offline
Old 09-04-2005, 01:12 PM   #15 (permalink)
good topic
roshbinarc is offline
Old 09-04-2005, 01:17 PM   #16 (permalink)
NikhilVerma's Avatar
I have a solution,.....
Take two wires
Connect them to your switch board...
Connect them to your RAM..
It will be fried internally in seconds...
[KIDS : Don't try this at home]
NikhilVerma is offline
Old 09-04-2005, 01:23 PM   #17 (permalink)
come on guys lets put our collective intelligence to some creative task.
**** happens
Old 09-04-2005, 02:11 PM   #18 (permalink)
why need title?
bharathbala2003's Avatar
u cant take it by ya hand and damage it cos once u hold it with hand the static is passed on to it.. and i suppose u can find out how it got damaged using a ROM READER... i think like ennonmai suggested wear a wrist band and hold it and u can keep it in front of a tv that is jus switched off or a comp monitor.. they will have the static that is enuff to damage it..
bharathbala2003 is offline
Old 09-04-2005, 07:43 PM   #19 (permalink)
The Hardware Labs
mohit's Avatar
How can i damage the RAM using the static electricity produced by my monitor/TV as Sankalp said ? Should i just take the RAM and place its gold pins on the TV screen or monitor and then turn it on ? Will that screw it ?
mohit is offline
Old 09-04-2005, 09:18 PM   #20 (permalink)
why need title?
yes it shld screw it to a certain extent.. but make sure u dont touch the inner part of the ram.. also keep the ram parallel to the monitor or tv... if there is static that is enuff to damage it will get..
Old 09-04-2005, 09:52 PM   #21 (permalink)
Wanna make sure that ur RAM goes out of order. Then try finding a van de graff generator somewhere near ur home.
I damn sure 1 million volts of static electricity is gonna do ur job.
Sankalp is offline
Old 10-04-2005, 12:31 AM   #22 (permalink)
mekalodu
iinfi's Avatar
well guys ...... if start a topic saying
"Tell me how a RAM is made ......"
how many of you will answer ....
one more idea ....
sell the RAMs saying its a good quality RAM .....
and buy new ones
and pleeeeeeeeeaaaaaaaaaseeeee do tell us what u did !!!
this is the best topic in the forum ...
Raaabo sud giv u a price .....
mekalodu
iinfi is offline
Old 10-04-2005, 01:12 AM   #23 (permalink)
rk
what is name of ur ram manufacturer
rk is offline
Old 06-08-2008, 03:51 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: How to damage a RAM module ?
Get that dealer, although the static trick sould get him and tell us what actually happened!
comp@ddict is offline
Old 06-08-2008, 04:07 PM   #25 (permalink)
Democracy is a myth
rhitwick's Avatar
U just bumped in a 3yr old thread..........
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 06-08-2008, 04:35 PM   #26 (permalink)
hullap's Avatar
was this on purpose?
hullap is offline
Old 06-08-2008, 05:02 PM   #27 (permalink)
Ask the manufacturer
paid is offline
Old 06-08-2008, 05:24 PM   #28 (permalink)
The Unknown's Avatar
KDE on ArchLinux
The Unknown is offline
Old 07-08-2008, 01:03 PM   #29 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
THis is the best topic on the digit forums yet adn i love this thread,
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 07-08-2008, 05:35 PM   #30 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I know this is bumped, but wrap the entire ram in aluminium foil, to make sure several parts of it touch the foil, and give it a nice 12/24 volt dc supply
dheeraj_kumar is offline
- by Piyush
