Old 16-02-2008, 09:26 PM   #1 (permalink)
budding doctor....
Default how to burn 3-4 movies in a single DVD
guys,
i want to burn 3-4 movies on a single DVD of 4.3GB but in VOB format so that it can run on older DVD players...
please tell me what should i do. i tired nero 8 but it does not change the quality of the movie automatically.
please let me know what to do. i have a huge collection on of movies and i want to put them on DVDs please suggest me some good softwares.
also please tell me is there any softwares which can split the movies automatically b/w CDs and burn them.
thanks in advance.
puneet_84 is offline
Old 17-02-2008, 09:19 AM   #2 (permalink)
webgenius's Avatar
Default Re: how to burn 3-4 movies in a single DVD
It's much better if you get a new divx player. You can get a new player for as low as 2k. Don't let your collection go waste. So get a better player.
webgenius is offline
Old 17-02-2008, 04:47 PM   #3 (permalink)
Try DVDShrink
ThinkFree is offline
Old 17-02-2008, 05:06 PM   #4 (permalink)
als2's Avatar
try ConvertXtoDvd
als2 is offline
Old 17-02-2008, 05:43 PM   #5 (permalink)
Gizmo Freak !
spitfire's Avatar
Use ashampoo shrink and burn 3....Its a hell of a software...just give it a try..you wll b amazed..
spitfire is offline
Old 08-05-2008, 01:11 AM   #6 (permalink)
budding doctor....
thanks guys for the help...i very much appreciate ur help
Old 08-05-2008, 08:00 AM   #7 (permalink)
The High 5 Flyer
sam9s's Avatar
DVD Shrink and DVDFab Platinum Best applications out there for all kind of DVD needs......both would let you do what you desire here giving you complete controll over quality and menus of the DVDs......
sam9s is online now
Old 08-05-2008, 10:15 AM   #8 (permalink)
Cool Buddy's Avatar
In nero vision when making dvd, go to options and select 'DVD extended play' or 'DVD long play'. it will fit more movies.
I've not used it for sometime, so don't remember the options exactly. just check it, you should get the options.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 08-05-2008, 11:59 AM   #9 (permalink)
Gracias Senor
dreams's Avatar
browse through http://www.videohelp.com/
u can get all tutorials under one roof.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 09-05-2008, 08:05 PM   #10 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
Just convert ur movie video to divx format and then u can also write 5-6 movies in a dvd.
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 09-05-2008, 08:36 PM   #11 (permalink)
Cool Buddy's Avatar
Read properly, his player doesn't support divX
Nokia 5230 :(
Old 09-05-2008, 08:39 PM   #12 (permalink)
"Aal Izz Well"
oops...
then try DVDShrink
Old 10-05-2008, 12:57 PM   #13 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
+1 with @webgenius ......
coz converting requires lotta TIME & faster processor ..... if u have BOTH go ahead .....
... W H O T ...
ax3 is offline
Old 11-05-2008, 01:12 AM   #14 (permalink)
The High 5 Flyer
sam9s's Avatar
if you have time u dont need a faster processor and if you have a fast processor you dont need time........
sam9s is online now
Old 11-05-2008, 10:46 AM   #15 (permalink)
QA Juggler
saROMan's Avatar
OK...so have seen lot of fuss about Bruning 3-4 Movies on 1 DVD..but after Intense Googeling..cudnt find a Proper Cure..so tryed doing R&D ...and Volla ..yes It is possible to 3-4 Movies on a DVD...hell you can Burn 8-10-14 Movies on a DVD...(Provided how much you are Ready to sacrifice on the Quality..)....i AM a Busy right Now ...so as soon as i get time will Post Comprehansive Tutorial as to How to Do it........Just for Time Being Jot Down the Basic Softwares you will Need ....
1 ) Nero Vision / Roxio Easy CD/DVD Creator
2 ) DVD Santa / Virtual Dub
Now I Normally Prefer the Vision+DVD Santa..but u can experiement with the Remaning 2 also...
Thumb Rule of 4 In 1 DVD ..dont Expect 652 x 356 Resolution Movies on your DVD ....There will be a Quality loss ...(Minor but Yes)
Will Give the Tute By EOD(Most Prob.. ) .....sorry to keep you Hanging in Middle...Just wanted to Convay the MovieThursty Pple that there is a Way
Edit : Done & Uploaded in Tutorials Section ..kindly chk it out....plz let me know if i have missed out any thing..
8-) सारोमान :!: :!: :!:
saROMan is offline
What is the best speed to burn DVD movies? ajayritik QnA (read only) 6 06-12-2007 07:13 PM
Request : Tutorial to burn 4 to 5 movies in a single 4Gb DVD gbaban Tutorials 2 24-01-2007 01:24 PM
Now playing: movies you can download and burn to DVD mihirvashist Technology News 3 30-07-2006 08:10 PM
how to burn 3 movies in single DVD ninad_mhatre85 Software Q&A 18 08-04-2006 08:55 PM
Burn Mandrake in a single DVD ???? plsoft Open Source 2 22-03-2006 10:41 PM
- by Piyush
