ELCOMSOFT has the Office Password Recovery Pro software for download here:
http://www.elcomsoft.com/aoxppr.html
However, the program is shareware, and also be warned that if you have set a medium to large length password, the program will spend hours trying to break the password. Usually, its just not worth the bother, as you can recreate the document in the time it finishes cracking the password.
