Old 15-02-2008, 03:39 PM   #1 (permalink)
mr.geniius's Avatar
Default need help about morange
I have nokia 6230i. i want to install the morange in mobile through mobile office,but it gives an error sayig that file is too large. i even tried to download the file in my pc and tranfering it to the card of my phone then it says that format not supported
mr.geniius is offline
Old 15-02-2008, 04:25 PM   #2 (permalink)
vaibhavtek
Posts: n/a
Default Re: need help about morange
Must Be in Mobile Section.
Old 15-02-2008, 04:44 PM   #3 (permalink)
Open your WAP browser and go here:
1) wap.morange.com
2) Then click the download link.
3) The Java file will get downloaded and installed.
As you have told that your phone is saying that file is too large, then you should try the MINI version: http://monet.morange.com/html.aspx?i...bile_mini.html
This should work I guess. The MINI version is only 160KB as compared to the 527KB of the main version.
Vaibhavtek, you had told that you've stopped spamming. But I guess you've started it again. I won't tell you to stop but I'll just say Quality never beats Quantity. You always post Must be in this section that section......... This is the last time I am advising you, but this surely depends on you to spam or not.
ico is offline
Old 15-02-2008, 04:48 PM   #4 (permalink)
slugger's Avatar
AFAIK morange needs Java Platform, Micro Edition (Java ME) for workin
try installin it and then install d morange appz
@vaibhavtek
@ everybodey else
y do u care what he is doing?
if you have a better reply, then just post it, else we will just have a god laugh over vaibhavtek's post count increasing tactics
and AFAIK his posts arent spmas they r all OFFTOPIC
slugger is offline
Old 15-02-2008, 04:50 PM   #5 (permalink)
@slugger: His phone Nokia 6230i supports Java.
Originally Posted by slugger View Post
@ everybodey else
I don't care actually. Thats why I wrote this is the last time I am advising.
ico is offline
Old 15-02-2008, 04:57 PM   #6 (permalink)
slugger's Avatar
i think its 6230i
and ok i dint know that it supported full java
mistake
slugger is offline
Old 15-02-2008, 06:25 PM   #7 (permalink)
mr.geniius's Avatar
but mini version also say invalid application.
Old 15-02-2008, 09:09 PM   #8 (permalink)
Elevating Humanity
The Conqueror's Avatar
u should make sure that u use the right edition of the symbian OS u have.
for eg u might be using Symbian OS 2nd edition software on symbian os 3rd edition
Regards,
The Conqueror
The Conqueror is offline
Old 17-02-2008, 07:47 AM   #9 (permalink)
mobilegeek's Avatar
Originally Posted by mr.geniius View Post
I have nokia 6230i. i want to install the morange in mobile through mobile office,but it gives an error saying that file is too large.
ok ..3 things
1. Noob_thing but plz remove the unrequired files from Phone memory,
2. Restart your phone
3. Try to install this file (I had this on my pc) - Morange for Nokia6230i
hope this works out ..
Regards
mobilegeek is offline
MORANGE -- Reclaim the power choudang Mobiles and Tablets 5 31-10-2007 12:14 PM
- by Piyush
