Old 07-04-2005, 05:18 PM   #1 (permalink)
nix
Senior Member
nix's Avatar
Default how to know battery level in UPS
i have a wiproeperiperal emerge UPS. is there any software which shows the power level in a UPS?
nikhilspoliticalblog.wordpress.com- Common man bows to amitabh
nix is offline
Old 08-04-2005, 01:22 AM   #2 (permalink)
swatkat's Avatar
You have to use the software present in the CD bundled with the UPS, to monitor UPS status and perform some extra tasks like auto-switch off etc.
You have to connect UPS to your PC through parallel/usb port, whichever is applicable.
http://swatrant.blogspot.com/
swatkat is offline
Old 08-04-2005, 03:19 PM   #3 (permalink)
Laptoping
Sourabh's Avatar
well this method doesnt work with most UPS
i tried it twice but it just shows some voltage settings and stuff
no din reply in this post
btw the one i tried on was the Powerware one , featured in 2003 digit last page whole year lol
are there any third party proggies to monitor coz even i have trouble with my UPS, rite now i have 2 separate UPS for my system
Sourabh is offline
Old 09-04-2005, 02:05 AM   #4 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Yes if youre using the emerge series from Wipro then you should have a program on a CD which should have come bundled with it called WePLogic ..if I remember correctly it should connect to the COM port .
FilledVoid is offline
Old 11-04-2005, 11:56 AM   #5 (permalink)
The Hardware Labs
mohit's Avatar
I am also using a Wipro Emerge series 600 va UPS but i dint get any WePLogic software or anything that connects to the COM Port. It was not specified on the Package Contents also. I know of Numeric UPS' which come with a similar feature like what you are talking about and they give a UPS Management software along with their UPS.
mohit is offline
- by Piyush
