Originally Posted by ax3
* when is the right time 2 buy\upgrade pc ?
sounds silly bt i know in that period u can save money ....
There is no right time to upgrade your PC. But sometimes if something new is right over the horizon, then it makes sense in waiting for sometime because prices may come down.
* how 2 find out hdd u r buying from vendor is new ?
As long as you buy it at some good place, it will be new. New HDDs are not formatted and you can make it out by the looks.(Not a reliable method to make out whether its new though)
* if i buy a SATA\PATA hdd now, will i b able 2 use it as master drive after i upgrade MB & processor say C2D ?
Yes. Go for SATA as its new and faster.
* will my AGP card get support in any new MB ?
NO. AGP is an old interface and new motherboards dont support it. Get a new Graphics card instead or settle down with onboard graphics if you are not a gamer.
