Old 07-04-2005, 04:30 PM   #1 (permalink)
Default Can Athlon 64 be overclocked???
Can Athlon64 processor be overclocked like the athlon XP. If yes then how
Sankalp is offline
Old 07-04-2005, 09:57 PM   #2 (permalink)
How come this is a tutorial??? this should be in the QnA Section. If u r asking for a tutorial then ask here
Shwetanshu Srivastava
shwetanshu is offline
Old 08-04-2005, 01:50 AM   #3 (permalink)
rachitboom2's Avatar
It depends on the MOBO that the CPU can be Over Clocked or not !!!
Which MOBO are you talking about ???
Laptop: HP DV6 - 6017TX: Intel Core i7 + 4GB DDR3 + ATI HD6770
Cell Phone: NEW Samsung Galaxy S2 i9100 16GB
Consoles: 3x Xbox 360 Slim 250GB Gamertag: Rachitmayhem
3x PS3 320GB Slim Gamertag: Rachitmayhem
mahule_rachit@yahoo.com
rachitboom2 is offline
Old 08-04-2005, 11:16 PM   #4 (permalink)
I have:
MSI K8N Neo Platinum with Athlon64 3000+ running @ 2.0 GHz
Well the mobo can be overclocked but what I wanna know is can the processor be overclocked in any way
And if so will it be safe
Sankalp is offline
Old 09-04-2005, 04:59 PM   #5 (permalink)
Yes it can be OC !!!
By increasing the clock multiplier !!!
Old 09-04-2005, 06:58 PM   #6 (permalink)
there is absolutely no difference in OCing a Athlon system or a 64 system. It still follows the same principle as above. The only factors which matter are CPU clock multiplier and the mhz (as in 166mhz or 170 and so on).
If these two can be adjusted then yes your cpu can be OCed.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 09-04-2005, 07:30 PM   #7 (permalink)
And How do i increase the clock multiplier
Sankalp is offline
Old 09-04-2005, 07:39 PM   #8 (permalink)
boot your system and goto the BIOS. From there there should be an option to increase the FSB. Increase it in steps of 4. Reboot. Check the system for stability. Form a complete tutorial here it is:
http://www.thinkdigit.com/forum/viewtopic.php?t=442
AMD 64 3500+ Venice
icecoolz is offline
Old 09-04-2005, 09:40 PM   #9 (permalink)
So that it means increasing the FSB increases the speed of the processor.
Is that what u mean
Sankalp is offline
Old 10-04-2005, 12:51 PM   #10 (permalink)
yes FSB and also the clock multplier. Read thru the tutorial mate. Its quite simple. And also do be careful. Increment it in small steps. Remem OCing is not officially supported by the CPU manufacturers and hence if you do fry ur cpu then u wont get a replacement. Read thru as much as u can b4 u even start attempting to OC
AMD 64 3500+ Venice
icecoolz is offline
Old 11-04-2005, 04:31 PM   #11 (permalink)
darklord's Avatar
On Normal Athlon 64's the Multipliers are locked.
For exampe if you have 3000+ which works @ 2.0 Ghz then the Multiplier is 10,you can reduce it but cant increase it above 10.
Also you can easily OC with that mobo+cpu.
darklord is offline
- by Piyush
