And i thought it was easy to work on powerpoint...anywayz, i have this ppt file with me very nicely designed with flash and all such stuff integrated into it.. I need to edit this file and the worst part is that i cannot change anything present on the slides.. i cant even click on the flash file embedded into it..which i wanted to remove.. Instead it shows up the default powerpoint "right click" menu when i click on it...
Is there any way out ??
no one ??
