Old 13-02-2008, 01:04 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default how to connect my 8600 to a TV.
i have a 8600GT 256MB DDR3
which has 2 DVI connectors, and i have a TV LG which has the normal jacks.
now how do i connect my pc to my TV.
what cables do i need and if possible mention the price.
thank you.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 13-02-2008, 01:53 PM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: how to connect my 8600 to a TV.
^^ you have have got a svideo to AV coverter with your card, connect that to the svideo port and the other end to the TV , switch to the AV on your TV and goto control panel > nvidia settings, from here you can enable TV out, usually it will automatically get detected.
Charan is online now
Old 13-02-2008, 02:40 PM   #3 (permalink)
chicha's Avatar
ok thank you dude.
thread can be closed.
chicha is offline
Old 13-02-2008, 04:17 PM   #4 (permalink)
chicha's Avatar
Originally Posted by chicha View Post
ok thank you dude.
sorry for that.
i tried does not work.
do i need to have the latest drivers?
when i connect the tv it flickers.
chicha is offline
Old 13-02-2008, 05:29 PM   #5 (permalink)
chicha's Avatar
ok i got the video output.
now how do i get the audio from the tv and the pc speakers.
this is how they are connected.
8600GT is connected to a 8pin cable which has 4 color jacks.
yellow- video
red - audio
green
blue
now also my mother board has a SPDIF out connector.
i tried connecting the red to that and to my TV.
but i did not get any sound.
i also have one more querry.
the TV is 21" what is the best res i can set and at what referesh rate.
thank you.
chicha is offline
Old 13-02-2008, 05:41 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
you have to connect the Audio input of TV to the Audio Out/Line Out of you computer.
EDIT: if you can then please post the screenshot of the cable.
And chicha.. the red blue green is to connect to you DVD input of TV , the red doesnot carry audio .
Old 13-02-2008, 06:40 PM   #7 (permalink)
chicha's Avatar
untitled is the end which goes to my TV.
untitled2 is the one from which i connect the cable to the TV.
i hope this helps.
how to connect my 8600 to a TV.-untitled.jpg   how to connect my 8600 to a TV.-untitled2.jpg
chicha is offline
Difference between 8600 GT and 8600 GT XXX? phreak0ut Hardware Q&A 2 31-10-2007 06:44 AM
How is XFX 8600 GTS?? iamthebsb QnA (read only) 8 29-09-2007 11:39 PM
Which 1 is better - XFX 8600 GT or XFX 8600 GT Fatality ??? kunwar QnA (read only) 22 31-08-2007 11:03 AM
Which 1 is better - XFX 8600 GT or XFX 8600 GT Fatality ??? kunwar QnA (read only) 1 27-08-2007 10:42 AM
- by Piyush
