Old 12-02-2008, 09:05 PM   #1 (permalink)
Default Sata or Pata DVD Writer to buy ...
i am planning to buy a DVD Writer for my PC. I've heard that sata optical drives gives problem while we need to boot from CD/DVD. is it true ? if true then wht the problem may be and wht will be its solution. shall i go for a sata optical drive or pata optical drive.
I have FOXCONN 45CM-S mobo which has 4 sata and 1 pata slot. can i install windows xp from scratch with xp bootable disk ?
give me some knowledge ...
passion_unlimitedd is offline
Old 12-02-2008, 10:27 PM   #2 (permalink)
slugger's Avatar
Default Re: Sata or Pata DVD Writer to buy ...
i am not aware of such problems arisin with SATA optical drives [even DIGIT did not report any in their test conducted this month]
havin siad this, if you are a home user with the normal requirements of a home user, i really don't see any harm in pruchsin a PATA either
performs reliably at acceptable speed, costs not very different, may not perform as fast but that shud not b a very big factor as long as you have a perfectly burnt disk
slugger is offline
Old 13-02-2008, 11:10 AM   #3 (permalink)
thanks slugger, the Chronic Intel Collector
i am also a die hard intel user like u.
Old 13-02-2008, 11:12 AM   #4 (permalink)
Rebooting
Choto Cheeta's Avatar
PATA for me
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-02-2008, 11:46 AM   #5 (permalink)
slugger's Avatar
OFFTOPIC
Intel not as in Intel® but intel as in Information/Knowledge
(eg. based on the latest intel recieved, it is believed the Osama.....)
I've been an AMD user since '99
slugger is offline
Old 13-02-2008, 11:59 AM   #6 (permalink)
Originally Posted by Choto Cheeta View Post
PATA for me
Hey Choto Cheeta,
Give your reasons for choosing PATA over SATA.
Let everyone know.
shadow2get is offline
Old 13-02-2008, 04:59 PM   #7 (permalink)
Originally Posted by slugger View Post
OFFTOPIC
ok !!
PATA for me
whts the reason ?
Last edited by passion_unlimitedd; 13-02-2008 at 04:59 PM. Reason: Automerged Doublepost
Old 13-02-2008, 05:18 PM   #8 (permalink)
damn busy...
utsav's Avatar
Man.go for sata.in pata drives u will surely face the problm of slow read and write speeds becoz many times the transfer mode changes to pio.in sata drives thr is no sucg problm
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 13-02-2008, 06:40 PM   #9 (permalink)
slugger's Avatar
d00d that has got NOTHING to do with any problem with with the PATA drive but it occurs when you you try to use a faulty disk
http://winhlp.com/node/10
show me 1 site [not a wiki or your own blog] that wil support your claim and i will show you 43600 sites to show you that SATA drives do go into PIO mode
slugger is offline
Old 13-02-2008, 07:43 PM   #10 (permalink)
Gizmo Freak !
spitfire's Avatar
It doesnt really matter.
Getting a sata ODD will not give you more speed...because even with the fastest sata writer..PATA can still deliver more than twice the bandwidth needed. But yes...when we have 52x dvd writers available (if at all )in the market..then sata becomes the only viable option
In fact I would say go for sata..but not for speed...but for
1.less cable clutter due to thinner sata wires
2.No master slave channeling
3.Samsung Sata drives costs less than pata now...
spitfire is offline
Old 13-02-2008, 09:37 PM   #11 (permalink)
The basic question is can i boot from sata dvd drive to install windows using bootable windows disks. because i heard from so many ppl tht sata drives are not capable of booting or gives problem while booting.
Old 13-02-2008, 11:38 PM   #12 (permalink)
Rebooting
yes its a problem as one cant boot due to missing SATA driver under XP... but all BIOS now days allow u to emulate the SATA as IDE
anyway I prefer PATA as there are no speed increase in because of SATA and later on we can increase HDD many mobo comes with 4 SATA port, no meaning of blocking one port with a DVD RW drive
rebooting
ChotoCheeta.com
Old 14-02-2008, 11:12 AM   #13 (permalink)
thanks. this clears all my doubts.
Old 14-02-2008, 11:45 AM   #14 (permalink)
99.9% Idle
axxo's Avatar
its not just PATA is old but every new mobo nowadys comes with single IDE connector.
So for upgraders its really a problem as they do sometimes have old IDE HDD so couple with that if you gonna buy a PATA writer you may end up with either slowing down the IDE channel or even run out of connecting slots.
axxo is offline
SATA to PATA ra_sriniketan Hardware Q&A 5 27-11-2005 10:43 PM
PATA or SATA anilthomas26 QnA (read only) 8 27-06-2005 02:09 PM
Sata or Pata ...... What is this. godsownman QnA (read only) 19 10-06-2005 06:41 PM
PATA and SATA tushar_novice QnA (read only) 8 27-03-2005 10:42 AM
SATA YA PATA nishantv2003 QnA (read only) 19 20-10-2004 11:12 AM
- by Piyush
