Originally Posted by ankushkool
where can i find this code???
not sure of d exact location of the code on the BOX, but when he shows you the processor, just look around the box, shud b there sumwhere i guess
and what is de Box Order code & OEM order code for E6600, E6550, E6750
all the inf that you would need can b found in the link dat i had provided earlier
does E6550 perform better than E6600???
not at all
if you compare the specs of the two processors, then you will find that except the clock speed they both have almost the same config
infact the E6600 has a lower thermal specification than the E6550
