LinkBack (1) Thread Tools Search this Thread Display Modes
Old 12-02-2008, 08:14 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Unhappy .DLL Access Denied :: Help Needed ! :(
Replaced the authui.dll file in windows vista with a modified one and now the windows gets stuck at the logon..
tried to replace the modified one using move on boot and unlocker but no respite !
dual booting windows vista and xp , but when i try to replace the file in system32 of windows vista , while logged onto xp , it gives an error message " Access Denied : MAke sure the file isn't protected or may be in use "
Waiting for a quick reply ,
Thnx
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 13-02-2008, 11:41 AM   #2 (permalink)
Default Re: .DLL Access Denied :: Help Needed ! :(
ne1 there to help ??
Old 13-02-2008, 01:10 PM   #3 (permalink)
left this forum longback
praka123's Avatar
boot any linux distro with ntfs write support like knoppix.mount ur win partition and do whatever you want
praka123 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/80174-dll-access-denied-help-needed.html
Thread .DLL Access Denied :: Help Needed ! :( | Digit Forum | BoardReader This thread Refback 17-12-2010 02:05 AM
Access denied?? prafulltcs Software Q&A 9 27-06-2007 07:34 PM
access denied ravidawar QnA (read only) 6 20-04-2007 08:46 PM
Access Denied Manshahia Software Q&A 4 30-01-2007 10:39 PM
Access is Denied! assasin Hardware Q&A 9 04-11-2006 04:46 PM
- by Piyush
