Old 12-02-2008, 07:05 AM   #1 (permalink)
rajat22's Avatar
Talking How can I swap my OS?
I want to swap my OS XP Pro SP 2 from one drive to another. I have 2 separate HD in my system.
Any solution??
Thanks.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 12-02-2008, 10:10 AM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: How can I swap my OS?
You can use some software like Acronis True Image or Drive Image to make an image of your old HDD. Restore it on your new HDD. Check your HDD manufacturers website, they might have some utility for this.
www.nerdweed.blogspot.com
casanova is offline
Old 12-02-2008, 11:50 AM   #3 (permalink)
You can clone your harddisk and then copy it to other one.
ThinkFree is offline
Old 12-02-2008, 12:01 PM   #4 (permalink)
vaibhavtek
Posts: n/a
yes clone ur hardisk and then swap..!!!!
Old 12-02-2008, 01:26 PM   #5 (permalink)
slugger's Avatar
AFAIK
creating a disk image and deploying it on another drive wil work only if
both the drive spaces are the same
and the partitions are both made active
else it wont work
slugger is offline
Old 13-02-2008, 03:57 PM   #6 (permalink)
rajat22's Avatar
Talking Re: How can I swap my OS?
Thanks to you all, Acronis True Image has solved my prob.
rajat22 is offline
swap deleted purujitb Open Source 4 29-12-2007 03:52 PM
Operating System Swap stellar Software Q&A 2 18-08-2007 01:06 AM
is swap a different partition ? saurabh kakkar Open Source 15 10-07-2007 05:54 AM
cpu swap question PAPABEAR Hardware Q&A 4 27-07-2006 03:02 AM
F.E.A.R. --HOW DO I SWAP? karthik55859 Gamerz 3 16-03-2006 08:29 PM
- by Piyush
