09-02-2008, 10:19 PM
Secure Html Images ?
I want to secure my html images on website. Suppose when someone try to click right click on my image than the pop will comes and shows the "Please don't save my images". how should i do. What the code ?.
http://www.miraclesoftware.in
Authorized Software Distributor - Online Software Shopping
09-02-2008, 10:41 PM
Re: Secure Html Images ?
javascript,
but a geek will always find a way to crack the measures.
09-02-2008, 10:55 PM
हॉर्न ओके प्लीज़
To protect images, simply add a © -your name, your site name on the image. Be sure that the images originally belong to you.
The disabling right-click method can foll noobs but not people who are 'determined' to steal your image.
गीक होना माँगता
09-02-2008, 11:05 PM
The Devil's Advocate
use watermarks+right click disable will definitely act as a deterrent
http://beingmanan.com
10-02-2008, 08:35 AM
How about CSS Images ?
Define a CSS class and give it the property background-image and others.
Be sure to deny access to the CSS file using apache .htaccess
<FilesMatch *.css>
Order allow,deny
Deny from All
</FilesMatch>
Place the above code in the directory where you store the CSSes in a file called .htaccess
KDE on ArchLinux
10-02-2008, 09:14 AM
but if a person save the page on his HDD, then nobody can be stopped from accessing the images
not a very hard thing to figure out
10-02-2008, 09:39 AM
THe best method I have found which is very secure & full proof is not put ur images on the web (public domain).....................nobody will see it ................hence nobody will want to steal it.
Rest all methods fail.
Web was meant for public sharing thats why its WWW.
10-02-2008, 09:59 AM
suppose you store the images under a uncommon directory i.e. other than img or images ; and use CSS method, then how will you steal images ?
KDE on ArchLinux
10-02-2008, 10:25 AM
There is a software that do that here
There is also a script:-
Put this on <head> section:-
<script type="text/javascript">
<!-- Begin
function whichElement(event) {
var tname
tname=event.srcElement.tagName
if (event.button==2 && tname=="IMG"){pressed="picture"}
if (pressed=="picture")
{window.alert("Oops !! Sorry !!")}
pressed=0
</script>
and whre u insert image type this
<img border="0" src="image path" onmousedown="whichElement(event)" usemap="#FPMap4"></p>
Hope it helps...!!!
The site : carmelite.netfirms.com is half made by me just visit there and goto Snaps section and right click the image.
In the last line of the HomePage see it is written:-
Maintained By: Vaibhav.
Reason: Automerged Doublepost
10-02-2008, 10:40 AM
<!-- Begin
var tname
pressed=0
</script>
Hope it helps...!!!
what about browsers who have disabled JS ?
also don't forget bots. they index images especially Google shows them in image results.
KDE on ArchLinux
10-02-2008, 10:42 AM
U seem to be ignoring the fact that css or no css the images still have to download to my computer & then I can do what ever I want.
Just go to IE temp folder & get the image...........................worse I can always take a screenshot.
Best method is not to post the image on the web.
Web is for showcasing & sharing not meant for securing, have u ever seen military maps on the web?
why not?
10-02-2008, 11:31 AM
why not?
you can prevent caching also by the HTTP header definition no-store
http://www.w3.org/Protocols/rfc2616/rfc2616-sec14.html
KDE on ArchLinux
10-02-2008, 12:26 PM
It wont let u save the image in cache for sure but you can still get the image from the cache without closing the browser.
No cache is only meant that once the browser is closed the the image should be deleted.
U always have the print screen & if u can find a way to disable that then there are many softwares to record the screen....................u have to find another method to disable these software too..................so the moral of the story is either be on the web or don't be on the web.
10-02-2008, 12:48 PM
KDE on ArchLinux
10-02-2008, 07:43 PM
I know only by JS.
I disabled i donot know how to then blick image.
And infact it can also be done by php but as i donot know that i cannot help.
Sorry..
But I am learning php...
10-02-2008, 07:56 PM
हॉर्न ओके प्लीज़
I know only by JS.
Sorry..
PHP?
Isn't it supposed to be a server side language?
btw it can't be done with PHP.
गीक होना माँगता
10-02-2008, 09:09 PM
I know only by JS.
Sorry..
its impossible to do in PHP
PHP generates HTML !!!!
KDE on ArchLinux
10-02-2008, 11:32 PM
Secure Image Pro OSX 4.0 can do what u want & I can copy the images when u use this, want to try????
http://www.download3000.com/download_21817.html
11-02-2008, 10:43 AM
#19 (permalink)
हॉर्न ओके प्लीज़
^ but how about screenshot using printscreen?
गीक होना माँगता
11-02-2008, 10:48 AM
#20 (permalink)
apply a water mark.
11-02-2008, 11:12 AM
#21 (permalink)
Rubik's Uncle!!
eh? comeon guys , all the images are cached before rendering, Just looking into Cache folder of the browser will give everyimage loaded. Once its loaded into memory it can be copied by any means. bestway to protect you images will be either watermark or my having creative common licence to it.
@booster : stop wasting time to learn how to avoid people to copy your image. Learn how to make the copied image always show you name/site.
11-02-2008, 11:26 AM
#22 (permalink)
see my avatar iv taken it from here. http://downloads.manutd.com/graphics...ship%20Winners
they hav protected the image by putting another image on it.
wht did i do?? simple i pressed the view source button
and voila \m/
IF they would hav applied a water mark then id be
SO U APPLY A WATERMARK
11-02-2008, 01:27 PM
#23 (permalink)
What purpose is that CC license going to serve  ? huh. even on CC license, if i copy an image and modify it using GIMP and use it somewhere else is it going to be found ?
So the moral of the problem is either don't place images on the web or don't try to protect them if placed.
KDE on ArchLinux
11-02-2008, 01:42 PM
#24 (permalink)
Rubik's Uncle!!
CC licence allows you to show/distribute you work with peace of mind, if anyone tries to take advantage of your work then you can sue them. Its similar to GNU, wodnt FOSS comunity sue me if I use code which comes under GNU, modify it and sell it without GNU licence.
11-02-2008, 02:04 PM
#25 (permalink)
suppose if nobody is informed of the copyright infringement ?
KDE on ArchLinux
11-02-2008, 02:10 PM
#26 (permalink)
Rubik's Uncle!!
^^^  .. dude .. thats the problem .. no matter what you do to protect you work it gets stolen. thats why the rules come in .. give your works with a rule. Microsoft does it with EULA , where as L!nux does it with GNU. in both case, if borken then the person can be sued. Finding out who broke it depends on the orginal author.
11-02-2008, 04:24 PM
#27 (permalink)
Cool as a CUCUMBAR ! ! !
have visited some sites where this thing was done .... cant remember the name bt will post asap ....
img r stored in their servers & not in ur cache\TIfiles .... amazing coding ....
will definately search & post ..... even i had posted this ? longtime back bt no ans .....
... W H O T ...
11-02-2008, 05:37 PM
#28 (permalink)
This non-caching feature is due to the HTTP header no-cache and no-store.
KDE on ArchLinux
11-02-2008, 10:04 PM
#29 (permalink)
use Flash to embed images.
[ॐ एसएमएस॰सोल्भर ॐ]
11-02-2008, 10:27 PM
#30 (permalink)
it will lead to running away of visitors as flash take much longer to load than normal images and also some visitors may not have flash player installed.
Even if we embed it, we can still capture the image using Print Screen!!!
KDE on ArchLinux
Search this Thread |
