Old 06-04-2005, 04:08 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Zone Alarm pro help ! ! !
i have installed Zone Alarm pro 5.1 on my w2k machine ...
i had setup a password ... bt now now i can`t remember it ...
even tried uninstalling it ... bt without password, it won`t ...
anywhere i could find my password ???
ax3 is offline
Old 06-04-2005, 06:46 PM   #2 (permalink)
Satissh S's Avatar
Try checking your inbox in your e-mail account!
If they hadn't mailed then use the shredder in spybot S&D to shread the entire application files and try reinstalling!
Or else there are some password finders available but using them is illegal!!!
Call it Emacs,
Love it or Leave it.
Satissh S is offline
Old 06-04-2005, 08:35 PM   #3 (permalink)
try running an installation without uninstalling, helped me with Zone Alarm Pro 5.5.
Shwetanshu Srivastava
shwetanshu is offline
Old 08-04-2005, 05:11 AM   #4 (permalink)
Fresh Stock Since 2005
If you have a legal version, you can ask help from online support.............
khattam_ is offline
Old 08-04-2005, 11:28 AM   #5 (permalink)
ax3
ax3's Avatar
no got it ...
just deleted some files ...
anyways thanx 4 ur help ...
... W H O T ...
ax3 is offline
- by Piyush
