Old 07-02-2008, 08:15 PM   #1 (permalink)
hrushij's Avatar
Unhappy Folder Locked?? ..pls hlp..!!
Hi..friends..
This time i am in great trouble..
In Xp I had made my folder privte...Now suddenly my system crashed..And I have installed new XP..SP2..Now It shows me "access denide" for that folder..!!
please...help me..!!
Thx in advance...
HHJobanputra
hrushij is offline
Old 07-02-2008, 09:38 PM   #2 (permalink)
Mad and Furious
redhat's Avatar
Default Re: Folder Locked?? ..pls hlp..!!
Sorry, no way out...
The encryption used here is pretty strong, cant crack it...
You have lost those files, but hey!! Didnt u take a backup?
I am not sure, but you may try some RAW data extractors..., might help...
redhat is offline
Old 08-02-2008, 03:07 PM   #3 (permalink)
vaibhavtek
Posts: n/a
No way.
Old 08-02-2008, 08:10 PM   #4 (permalink)
SivaChand
Which software you used for lock?
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
Old 08-02-2008, 09:22 PM   #5 (permalink)
In search of light...
abhi.eternal's Avatar
Get a Ubuntu live CD/DVD and boot LIVE. then access the folder and copy the files to another folder/drive. I heard (but dint try) that Ubuntu 7 can write on NTFS. So if you have NTFS drive, delete the folder after copying the files.
http://abhijeetdeb.com
abhi.eternal is offline
Old 08-02-2008, 10:43 PM   #6 (permalink)
Fresh Stock Since 2005
I'm not sure if this works, but you can give it a try:
Log in as administrator or user with admin privilages, if you haven't already done so.
Check you system time. Lets assume it is 10:50 PM.
Open Command Window and then type in the following:
at 22:52 /interactive "cmd.exe"
If your system time is 1:00 am for example, you shud do:
at 1:02 /interactive "cmd.exe"
Add 2 minutes to the system time. Hope this is clear.
Then close command prompt.
Now, press Ctrl+Alt+Del and then end the Explorer.
Then wait for 2 minutes, roughly. You will see another Command Prompt.
Type in "explorer.exe" in your new command prompt. You should be logged in as system user, and not your user.
Now, navigate to the folder and try accessing it. If the data was not encrypted, you may have some luck. Not sure this works, but you can give it a try.
Also, if the above procedure does not work and if your data is critical, you may consider buying "Advanced EFS Data Recovery" which might help.
http://www.khattam.info
khattam_ is offline
Old 08-02-2008, 10:48 PM   #7 (permalink)
TheSaint
NucleusKore's Avatar
If it is encrypted how can ANY OS read it?
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 10-02-2008, 06:41 PM   #8 (permalink)
i don't know. i tried this method once and it worked for me (i used Ubuntu 6). may be it is encrypted to windows architecture only and not linux.
Old 10-02-2008, 07:14 PM   #9 (permalink)
TheSaint
Old 11-02-2008, 03:07 PM   #10 (permalink)
I think it might have something to do with "header information" or something.. Its just a vague, supposedly intuitive guess. Pardon me if its absurd.
what i tried to say is, something like when you open the folder, it checks for some header information to check if its encrypted or not before opening... like say, how a photo-editing software could load the details regarding compression header information stored in a jpeg file... this encryption strategy might be different in linux... ??? if it works.. this hyper-intuitive alienistic thinking might be right!!
sorry guys, i need to rest my brain i guess
legolas is offline
Old 11-02-2008, 06:18 PM   #11 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
how did you actually do that. . can you tell the steps .. each n every step plz.,
i am not a noob but want to know how you do it .. so that we might be able to solve it
but its very very rare chance .. bcoz .. it has been encrypted to an unknown coding flowchart
windows encrypted it .. and we dont know what coding it used. unless we know that we cant decode.
Ubuntu wont have the windows cert files
rollcage is offline
Old 11-02-2008, 06:48 PM   #12 (permalink)
Commander in Chief
QwertyManiac's Avatar
Hmm you just need to get back the ownership of that folder/file.
Read the guide given here: http://support.microsoft.com/kb/308421
Guys: He hasn't encrypted it via that encrypt attrib NTFS gives, rather he's just set private permissions. And Ubuntu or any other OS which is not Windows hardly care for permissions while reading a file off their usual file-systems. Thus it can be read and written to, but if encrypted, obviously not.
Harsh J
www.harshj.com
QwertyManiac is offline
MY Vista doesn't have copy folder and move folder option. tamilvendan Software Q&A 2 05-12-2007 10:12 PM
Making Folder Option Disable to make Folder Private vaibhavtek Tutorials 10 04-11-2007 11:55 PM
Locked Out Of Xp mihirvashist Software Q&A 1 28-11-2006 08:23 PM
WinXP private folder locked mapuia Software Q&A 5 01-03-2005 11:10 AM
- by Piyush
