Old 04-02-2008, 09:16 PM   #1 (permalink)
cluby's Avatar
Default Please comment on the prices
I bought the following config from kolkata today
ASUS M2N-VM DVI-----------------Rs.3475
AMD 64 AM2 4400+----------------Rs.3800
2GB*1 DDR2 800MHz---------------Rs.2550
Seagate 250GB 7200rpm-----------Rs.2850
Please comment on the prices .Are they high or normal.
If I hd gone for 1GB*2 would the price be less.
cluby is offline
Old 04-02-2008, 09:27 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: Please comment on the prices
AFAIK you should have bought 1GB*2 RAM modules as it would increase system performance. As far as prices are concerned, I guess they are OK.
Check prices here:
http://theitwares.com/
narangz is offline
Old 04-02-2008, 09:32 PM   #3 (permalink)
cluby's Avatar
I have already planned to buy another 2GB*1 next month so performance will not matter then.
Anyways thanks for reply.
cluby is offline
Old 04-02-2008, 09:33 PM   #4 (permalink)
Web developer
narangz's Avatar
Yeah then its OK.
You are welcome mate.
narangz is offline
Old 04-02-2008, 10:06 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
ASUS M2N-VM DVI---------Rs.3475 <- OK
AMD 64 AM2 4400+--------Rs.3800 <- get iether 4200 or 4800 but no 4400
2GB*1 DDR2 800MHz-------Rs.2550 <- get single stick DDR-II 667 MHz kingstone at Rs. 1800/- + 4% VAT
Seagate 250GB 7200rpm----Rs.2850 <- if 16 mb buffer then ok
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 04-02-2008, 10:23 PM   #6 (permalink)
harryneopotter's Avatar
y r u suggesting him 667 mhz ram instead of 800 mhz ??
harryneopotter is offline
Old 05-02-2008, 02:05 AM   #7 (permalink)
Rebooting
there are really no performance difference between 800 and 667 value rams yes if one can afford a performance 800 Mhz such as crosair or such then yeah
as if buying 2 GB single stick 667 at present, gives u a real flexibility Rs. 1800/- + TAX for kingstone 667 MHz 2 GB which in next few months would hit Rs. 1500/- mark and then u can add another 2 GB to make is 4 GB under dual channel
rebooting
ChotoCheeta.com
Pc Config; Comment BloodReaper PC Components / Configurations 27 26-12-2007 04:29 PM
ur comment req vamsum_kris QnA (read only) 5 06-12-2004 10:17 PM
- by Piyush
