Old 04-02-2008, 10:46 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Format & Install ???
as title suggest >
diff between formatting from winxp installation cd or win98 bootable floppy ?
which is fastest & rightway ?
... W H O T ...
ax3 is offline
Old 04-02-2008, 11:35 AM   #2 (permalink)
slugger's Avatar
Default Re: Format & Install ???
nothin wron with choosing either option
just dat if u doin it with d XP CD u have the option of creating and formattin NTFS partitions
not possible 2 do dat with a 98 boot floppy-only FAT32 possible with this
also if ur parition is gr8ter than 32GB u will not b able 2 use d 98 floppy
slugger is offline
Old 04-02-2008, 12:24 PM   #3 (permalink)
ax3
ax3's Avatar
& speed\fast ? or is it same .......
... W H O T ...
ax3 is offline
Old 04-02-2008, 12:33 PM   #4 (permalink)
slugger's Avatar
y dis obsession with floppies and dat 2 '98??
use a bootCD [XP or any other] to format ur disk will offer you better options and more reliable
slugger is offline
Old 04-02-2008, 12:37 PM   #5 (permalink)
ax3
ax3's Avatar
just clearing my doubts, frd .... coz sometimes it takes a lotta time 2 just copy those XP installation files 2 hdd .... have seen @ my frds place ......
... W H O T ...
ax3 is offline
Old 04-02-2008, 12:50 PM   #6 (permalink)
slugger's Avatar
now u r making no sense at all
wat is the connection between formatting a HDD and copying files to the HDD
if ur aim is 2 copy the XP setup files to the HDD, how will formatting ur HDD with a '98 make any difference to the copying speed from the CD
n e way copying files to the HDD does not depend on what program u have used to format d isk as long as u have formatted it properlt [proof of job well done: you r able to access the dive and cre8/copy/cut files to the drive without any error messages]
slugger is offline
Old 04-02-2008, 01:17 PM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
Formatting with the same settings is same regardless of the way you format.
infra_red_dude is offline
Old 04-02-2008, 01:26 PM   #8 (permalink)
ax3
ax3's Avatar
@slugger ....... after format dont u have auto copy of xp files on2 hdd before installation ......
... W H O T ...
ax3 is offline
Old 04-02-2008, 01:39 PM   #9 (permalink)
slugger's Avatar
the speed of that copying has got nothing to do with the method u have used to format the HDD earlier
if ur drive spped is slow or the disk u usin to install the OS is scratched, then it is bound to take longer time to copy
if speed is what u want then best method is to copy the setup files on2 some other drive of the HDD b4 u format the other drive [where u wan2 install d OS] and start the install running the winnt.exe file from that location
slugger is offline
Old 06-02-2008, 11:16 AM   #10 (permalink)
ax3
ax3's Avatar
@slugger ..... thanx .... u cleared my doubt ...... had a wrong concept in my mind which was explained\suggested by my frd [comp guy] ...... & its hard 2 maintain a floppy disk nowdays .....
... W H O T ...
ax3 is offline
Old 06-02-2008, 11:24 AM   #11 (permalink)
-----ATi-----
nvidia's Avatar
Maintaining a floppy is like maintaining a girl friend these days...
http://twitter.com/akshayms
nvidia is offline
Old 06-02-2008, 12:30 PM   #12 (permalink)
slugger's Avatar
no probs man
slugger is offline
Old 06-02-2008, 12:43 PM   #13 (permalink)
Wire muncher!
Why would anyone wanna maintain a floppy? Its boot image can be extracted and burnt to a bootable CD. Plus you can also add many DOS based diagnostic utilities. So that way you get the advantage of using a floppy for booting into DOS mode and many utilties. You can even run windows setup from HDD that way to speed up the copying process
Old 06-02-2008, 05:14 PM   #14 (permalink)
ax3
ax3's Avatar
@nvidia8800 ..... nice 1 ......
@infra_red_dude .......
why & whots diff between copied bootable floppy [doesnt work] & a floppy created through floppy boot image [works] ?
... W H O T ...
ax3 is offline
Old 06-02-2008, 05:42 PM   #15 (permalink)
Wire muncher!
Works or doesn't for your setup I dunno. Just commented that floppies are passe. The boot image can be burnt on CD and all the things can be had via the CD too (booting in to dos mode etc.)
Old 07-02-2008, 04:15 PM   #16 (permalink)
ax3
ax3's Avatar
works 4 me ...
bt just wanted 2 know, if v JUST copy that floppy & try booting from that 1 , booting not possible .....
bt create from boot img or OS, it works .....
why so ? ..... just wanted 2 know some technical ans ......
... W H O T ...
ax3 is offline
Old 07-02-2008, 05:25 PM   #17 (permalink)
slugger's Avatar
a image of a bootable floppy created on a CD emulates the environment of a floppy.
the files on a bootable floppy are coded to operate under archtecture specifice to a floppy - its space, data transfer speed, its tracks, sectors arrangement etc. It is obviously different from that of a HDD
So altho we know that the disk is a CD, the files in the boot image operate in an environment emulating a floppy, so they can perform without issues
slugger is offline
Old 09-02-2008, 04:45 PM   #18 (permalink)
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
wht an ovservation ... seems u have great experiance in maintaining both .... (off topic : sorry cud not resist myself)
passion_unlimitedd is offline
Old 09-02-2008, 11:56 PM   #19 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
offtopic man ,, you have been around since 2003 and just 33posts
rollcage is offline
Old 10-02-2008, 02:42 AM   #20 (permalink)
dOm1naTOr's Avatar
Use a bootable discs with Partition magic. U can easily boot into it nd can perform formating, repartitioning, merging, resizing all these w/o ny problem at vesy faster rate than the winxp or win98 bootable disc.
And also i think u can't format sata HDDs using a bootable floppy. Ivent tried as ive no floppy drive.
And why not make a bootable to DOS CD and use command prompt to format the partitions using fdisk? but maynot work with ntfs partitions.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-02-2008, 10:13 PM   #21 (permalink)
Wire muncher!
If formatting and partitioning is the only job then use GPartED. Nothing better than it! Its a bootable partition manager and can handle everything!
Suggest how to copy movies from CD format to DVD format? please help.its urgent tomdickharry QnA (read only) 2 17-10-2006 01:14 PM
how to format and install xp bhola123456 Software Q&A 7 07-05-2006 05:44 PM
<Help> Howto format and install windows using external drive a_medico Software Q&A 1 14-03-2006 12:58 AM
can WINDOWS98 be install on NTFS format digiFriend Software Q&A 5 11-03-2006 11:30 AM
Cannot access files after a format and fresh install sid_ashok QnA (read only) 5 16-02-2006 11:00 AM
- by Piyush
