Old 03-02-2008, 09:48 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default how to utilize pen drive for maximum capacity?
i have a kingston data traveller 100.
its a 4GB pen drive but only show 3.73 GB so i am missing good 200MB!!
how can i gain that?
i tried converting it into fat system but i could not.
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 03-02-2008, 10:08 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: how to utilize pen drive for maximum capacity?
You cant do anything. 4GB = 3.73GiB.
Pathik is offline
Old 03-02-2008, 10:21 PM   #3 (permalink)
dOm1naTOr's Avatar
For thumbdrives nd HDD the real size is less than the specified. This is lost due to farmating.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 03-02-2008, 10:26 PM   #4 (permalink)
FAT16 or simply FAT doesn't support partitions over 2GB, so you can't use FAT for your pendrive. You'll have to use FAT32
And 4GB = 4 * 10^9 bytes = 4000000000 bytes
4000000000 bytes (divide by 1024) = 3906250 KiB = 3814.7 MiB = 3.73 GiB
So this is the maximum you can use.......
ico is offline
Old 03-02-2008, 11:54 PM   #5 (permalink)
ayush_chh's Avatar
^^ very correct ....
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 04-02-2008, 07:29 AM   #6 (permalink)
vaibhavtek
Posts: n/a
how u know that 4 * 10^9 = 4 GB i.e. how you got that it is 10^9 why it is not 10^8..???
Hope u understand what i am asking..
Old 04-02-2008, 09:00 AM   #7 (permalink)
chicha's Avatar
ok.
now i formatted it with a NTFS. what is better NTFS or FAT32?
which is faster?
chicha is offline
Old 04-02-2008, 10:14 AM   #8 (permalink)
vaibhavtek
Posts: n/a
Cool Re: how to utilize pen drive for maximum capacity?
^^ NTFS.
---------------------550 Posts------------------------
Old 04-02-2008, 10:50 AM   #9 (permalink)
prasad_den's Avatar
^^ come on dude... don't say you don't know 1GB is 1000 MB and 1 MB is 1000KB and 1KB is 1000B.. So do the math yourself... and stop counting your total number of posts..! that'll take you nowhere.!
prasad_den is offline
Old 04-02-2008, 10:52 AM   #10 (permalink)
vaibhavtek
Posts: n/a
^^ 1 GB = 1024 MB and u say 1 GB = 1000 MB and same with KB and B.
Anyone plz help.
Old 04-02-2008, 10:57 AM   #11 (permalink)
prasad_den's Avatar
^^ Thats because manufacturers count them in 1000s while the computer still identifies a KB as 1024B.. Tht's the reason why your computer shows 3.73 GB on a pen drive while the manufacturer insists its a 4GB one. Both count differently.
Old 04-02-2008, 11:15 AM   #12 (permalink)
ashfame's Avatar
Any softwares for testing the read write speed of pen drives.? I have a kingston 4gb (bought it for Rs.750 ) and wants to benchmark it.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 04-02-2008, 11:32 AM   #13 (permalink)
Mad and Furious
redhat's Avatar
+1 True....
This is still a confusion, since some count 1GB as 1024MB n others as 1000MB...
redhat is offline
Old 04-02-2008, 03:08 PM   #14 (permalink)
vaibhavtek
Posts: n/a
thanks I got that.
Old 04-02-2008, 03:18 PM   #15 (permalink)
chicha's Avatar
me too paid Rs 750.
and this pendrive can be used as READYBOOST.
so the conclusion is that i can not regain that 200MB
yes are there any softwares that can benchmark pendrives?
chicha is offline
Old 04-02-2008, 03:28 PM   #16 (permalink)
Originally Posted by chicha View Post
ok.
which is faster?
Originally Posted by vaibhavtek View Post
^^ NTFS.
NTFS is surely a better file system but it is not for use on Pen Drives. Using your Pen Drive will actually decrease its lifetime as it will increase the read/write cycles because of the feature of Write Cache in NTFS. Write Cache (NTFS) will surely increase the speed of writing files but at the cost of the life of your pen drive.
So, I'll say to use FAT32 on your Pen Drive.
ico is offline
What Is The Maximum Memory Card Capacity Supported By SE K810i? unni Mobiles and Tablets 3 20-09-2007 03:35 PM
Multiple HDD with small capacity or one HDD with large capacity? Anindya QnA (read only) 2 19-05-2007 02:22 AM
Maximum capacity of Cds simoncherian QnA (read only) 33 15-04-2006 08:02 PM
Can Nvidia 6600 GT AGP utilize 256 MB yogeshglx Graphic cards 2 14-04-2006 03:20 AM
pen drive shows less capacity... gauravakaasid QnA (read only) 2 25-07-2005 11:18 AM
- by Piyush
