Old 05-04-2005, 05:13 PM   #1 (permalink)
Default ISO Reading
I have a ISO image, I want to read from Hard disk without buring to CDROM. what's d way
ilias is offline
Old 05-04-2005, 05:19 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
Download daemon tools from here
Sourabh is offline
Old 05-04-2005, 05:36 PM   #3 (permalink)
NikhilVerma's Avatar
Download "Daemon Tools"....
Or get them from the Digit DVD ....
It can load the ISO image as a drive...
NikhilVerma is offline
Old 05-04-2005, 05:39 PM   #4 (permalink)
Or just use a tool like WinRAR,which can read from the ISO file as if it were a zip file or something
Daemon tools will also be able to emulate the ISO as if it were a drive in your system.
Oh and btw, you have not mentioned your OS, the above information is for windows, on linux, use the "mount -o loop xyz.iso /mnt/cdrom" to mount the ISO on /mnt/cdrom.
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 05-04-2005, 05:49 PM   #5 (permalink)
parthbarot's Avatar
no buddy..
instead use "Alcohol 120%"...
its grt read more extensions.....
www.techlads.com
Paarth.
parthbarot is offline
Old 05-04-2005, 05:58 PM   #6 (permalink)
Laptoping
Sourabh's Avatar
plz google for info on daemon tools
even it supports hell lotta formats
also its a freeware
IMO its the best
Sourabh is offline
Old 06-04-2005, 04:04 AM   #7 (permalink)
The contents of images files can be extracted to hard drive using utilities such as
ISObuster: http://www.isobuster.com/ or
DaemonTools as provided by Sourabh
http://www.daemon-tools.cc/dtcc/portal/download.php
I prefer to use ISO Buster though I haven't tried Daemon tools.
RajŪ Anyone else is not me...!!!
rajas is offline
Old 06-04-2005, 10:56 AM   #8 (permalink)
Default RE
Use WinISO
ganesh_dabhade is offline
Old 06-04-2005, 11:24 AM   #9 (permalink)
why need title?
bharathbala2003's Avatar
try Undisket i use it and its good..
bharathbala2003 is offline
Old 07-04-2005, 10:43 PM   #10 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Use UltraISO, MagicISO or WinRAR. With UltraISO and MagicISO you can burn ISO but WinRAR only reads ISO not as a cd image but as a archive.
navjotjsingh is offline
- by Piyush
