Old 01-02-2008, 12:08 PM   #1 (permalink)
Default this is a problem or what?
hello friends i have a compaq presario v6000 laptop and a desktop.when i browse net on the desktop my broadband speed is 75 to 125.135 kbps,but when i use broadband on my laptop it gives the speed of between 25 to 30 kbps. before 2 days i formated my laptop. i use win xp sp2.mcafee antivirus.please friends give me the solution,how to increase the speed of my laptop.
babuli_05 is offline
Old 01-02-2008, 12:47 PM   #2 (permalink)
Fresh Stock Since 2005
Default Re: this is a problem or what?
try some tweaking......... just a suggestion though...
http://www.khattam.info
khattam_ is offline
Old 02-02-2008, 12:54 AM   #3 (permalink)
Hi,
With the information you have provided, there is not much of a suggestion I could provide. However,
1) did you check if your antivirus (if it has a firewall) is configured to block certain programs and u were using that program?
2) Or do you have any other netlimiter program installed?
3) this is pretty dumb, but hey you dont know... it sometimes might be the issue.. do you connect to both the systems (for ex: using a splitter) or using a router?? If so, try and see the configuration for those.
4) try and install all updates released after sp2 if u haven't. It might fix your troubles.
I will update in case I think of something else.
BTW, Please title your query properly so that it would help others.
@Khattam, your reply to this post and your signature are kind of interesting (just kidding)
legolas.
legolas is offline
Old 02-02-2008, 02:39 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
The problem can also be due to multiple telephone connections for the same number.This is my personal experience. I was getting download speeds of only 125-150 KB/s in 2 Mbps Dataone Connection. The reason was I was having 2 Telephone Instruments connected to the line. Once I disconnected the 2nd Line I am getting 200-225 KB/s
techtronic is offline
Old 02-02-2008, 09:30 AM   #5 (permalink)
SivaChand
U r using the internet connection by LAN or Wireless for your Lappy?
Always look at what you have left.Never look at what you have lost
kpmsivachand is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by Piyush
